Ride: 01 is300, 05 s2000, 03 rx300
http://www.hondaswap.com/~pills/lsvtec.html
here are some new pics and stuff... i got the head modified for the new dowel pins, plugged the oil feed in the head, got the head a mild port and polish, the block is almost assembled, but the 2nd rate bore job bent a set of rings on cylinder #3, but i've since fixed that problem. anyways.. enjoy the pics, today i'm just about to go drop my LS fifth gear into the ITR tranny.. maybe make a how to or something... later |
GNU/Linux Evangelist
Ride: The Cheapest Road Bicycle I could get
Lookin good. I look forward to seeing the results.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com |
#3 | |
Admin with a big stick
Ride: 2003 S2000
the 5th gears were incredibly eaSy to switch. everything just lifts out as a whole.. i had to press the bearing off the main shaft .. but really not hard... i took pics, i'll try to write something up for it and post them soon.. i 've been crazy busy lately
#5 |
Calesta, the ZC final swap is pretty easy. just swap the ring gears and then pull everything off both countershafts and swap them. Keep everything in order when you take it off and you are good. While you are at it you can swap 5th. The pain is actually getting the tranny case off and back on. Remember the bolts on the diff are reverse threaded.
Pills did you get a cable or hydro 5th any clarity on interchangability? __________________
<a href=\'http://www.knology.net/~jediklc/\' target=\'_blank\'>My Webpage</a> <a href=\'http://www.geocities.com/DawgSol94S/Welcome.html\' target=\'_blank\'>Team Sol Georgia</a> |
#6 |
Ride: 2003 S2000
Ok, that sounds pretty straightforward. What about the ring gear bolt pattern on the ZC LSD compared to the Si non LSD?
#7 |
it's a hydro ITR tranny and I got the gear brand new from acura/honda for a 95 acura integra LS...
i didn't want to take the chance with the cable/hydro gear swapping... |
#8 | |
Ride: 2003 S2000
![]() __________________
#9 | |
| HOW TO STOP BARKING DOG??? | reckedracing | Members' Lounge | 12 | 04-02-2004 06:13 PM |
| CD-2 Engine Sealer to stop oil burning | sportlinecrx | Members' Lounge | 27 | 12-08-2003 11:50 AM |
| It's Really Not Working ? | Drenni | General Tech and Maintenance | 1 | 06-16-2003 10:29 PM |
| Civic Dies At A Stop | randerson165 | General Tech and Maintenance | 6 | 01-17-2003 04:01 PM |
