Begginers Guide to Performance
Old 01-24-2007, 08:47 PM   #1
wek sos
JDMEG-6's Avatar
Ride:  EG-6 hatch
Rep Power: 6 JDMEG-6 is on a distinguished road
Post Begginers Guide to Performance
A few things to look at before getting started with a performance plan. You might be in a different category so read which one you will be in.
Make sure to view this page in a full alone screen.LevelsStage IStage IIStage IIIStage IVStage VStage VIStage VIIGainsFree Home-made PlanHome Made intake and K+N
2-5hp
Hand Port and Polish exhaust ports
1-2hp
Polish Throttle Body
1-2hp
Advance Timing
1-3hp
Hollow Cat / Weld-In Test Pipe.
2-5hp
Remove Power Steering Belt
2-3hp
9hp-18hpHidden Performance
$2000-6000
Drop In K+N Filter $80
2-5hp
Throttle Body $250
4-6hp
Extrude Hone the Stock Header
$200-400
3-4hp
Test Pipe/HF. cat/ Or hollow $100-300
5-10hp
1.6L Dohc VTEC can upgrade to a 1.8L Bottom end
$1000
More hp/tq
Race Head
$500-4000
5-50hp
Hidden Nitrous System
$500-800
25-75shot
55-175hpCheap Plan
Cost $400-700
Cheap Intake $100
5-8hp
Nice Header $300
7-9hp
Throttle Body $250
3-6hp
15hp-24hpSimple Plan
Cost $800-1200
Cold Air Intake $230
8-10hp
Race Header
$420
9-13hp
Exhaust
$400
8-12hp
Throttle Body $250
4-6hp
27hp-31hpBudget Racer
$1300-2200
8-10hp
Race Header
$420
9-13hp
Exhaust
$400
8-12hp
Throttle Body $250
4-6hp
Underdrive pulleys $250
4-5hp
Cam Sprocket $250
2hp-5hp.
31hp-51hpStreet Monster
$2500-5000
Turbo Basic $2500-4000
70-110hp
Test Pipe/HF. cat $100-300
5-10hp
Exhaust
$420
10-15hp
Throttle Body
$250
6-10hp
6-8hp
Cam Sprocket $250
5hp-10hp
Wires / Spark Plugs $150
2hp-4hp
104hp-167hpAll out race
Cost 10,000-????
Custom Race Turbo
$4000-9000
200-400hp
Electronic / Fuel Race Ignition
$800-2200
10-30hp
Custom Race Exhaust
$800
12-20hp
Race Intake Manifold
$800-2500
25-60hp
Race Head
$1200-3000
20-80hp
267-590+
These plans are just for helping you figure out which way to go. How much horsepower to expect and perhaps what category restrictions you might be limited too. For the hidden performance its for those that want to either look stock for just fun or to hide it from the dealer or anyone else. These results might not be exact , but these are tried and true real world prices and dyno's that provide the info. Also the parts used are just some of the parts that can be used. Of course there's more to add on to some or some can skip some and use some of there own. These parts were selected by there availability and popularity. More exotic parts and others weren't used since they basically don't do much or are really hard to get.
As For Suspension Goes its simple....pay more handle better. Stage IStage IIStage IIIStage IVStage VSuspension PlanSpring Only
$100-200
Spring and Shocks-Non Adjustable
$400-800
Spring and Adjustable Shocks
$700
Coil-Overs
$1200-1500
Full Race Coil-Overs
$1500-2200
Explanation - About the suspension changes and difference in levels.Quick easy install , some kits lower too much for looks and you get a unsettled ride which isnt good for high speed bumps. Stock shocks will soon go.Now you have something to work with , even though they might be out of synch.This one you have a lot more to work with , you can adjust the shocks at least to try to match the springs and the car better. Yet still probably wont have a lot of travel, and you might just get a product that doesnt go well togetherThese systems if really made for your car handle the best can be tuned like the stageIII but also have a bit more spring rate, ride height and travel. Which can help a lot. Street / Drag or CourseAgain just like stage IV but probably a higher known competition name or perhaps the shocks will have their own reservoir....which sometimes are controlled electronically from the car.
Brakes , bigger better stronger....pay morestop quicker. Stage IStage IIStage IIIStage IVStage VBraking PlanSports/Race Pads Only
$100-200
Pads and Rotors
$400-800
Sport Brake kit
$700-1000
Race Brake Kits
$1100-1500
All out race.
$1500-2000
Explanation - About the brake changes.Upgrading to more efficient brake pads, some might cause some sound or more brake dust so watch out.Slotted Rotors are suggested for Street Cars and race pads will do. Just make sure their not some crazy kind that need to be real hot. Also good to add race/dot4 brake fluid.Great for the street, possible new caliper, might need bigger rims. If your not really going fast then this might be overkill, but then again you might like safety. Also consider changing lines.Made for high heat all the time applications , more emphasis on cooling and anything to do to slow down. This is because on the track you are on the brakes a lot. The street you brake a bit and then cruise. Just like before but Anything from really oversized rotors & dual calipers .To materials made to handle anything. These kits will make any street tire the bottle-neck for braking faster.
im so jdm i sleep on the right side of the bed..
JDMEG-6 is offline   Reply With Quote
Old 01-24-2007, 10:45 PM   #2
Got Rice?
801CRX's Avatar
Ride:  89' CRX HF and 90' Civic Si
Rep Power: 27 801CRX is just really nice801CRX is just really nice801CRX is just really nice801CRX is just really nice
Ummmmmm..........................I cant understand anything I just read in your post dude.
Clean that shit up!
www.supremacyracing.com
801CRX is offline   Reply With Quote
Old 01-24-2007, 11:42 PM   #3
Grand High Wizard
tartymctang2357's Avatar
Rep Power: 10 tartymctang2357 will become famous soon enoughtartymctang2357 will become famous soon enough
Send a message via AIM to tartymctang2357
anyone notice that they don't say anything about going all motor? like they go from talking about bolt ons right to a turbo, wtf wheres the block build up, i would think that they would have at least included that in the monster build part, i'm gonna have to give it a big thumbs down for anything good
tartymctang2357 is offline   Reply With Quote
Old 01-25-2007, 03:58 AM   #4
wek sos
JDMEG-6's Avatar
Ride:  EG-6 hatch
full alone screen.
Old 01-25-2007, 05:52 PM   #5
Got Rice?
801CRX's Avatar
Originally Posted by Blanco View Post
Way to be lazy.
Hahahahaha
Old 01-27-2007, 04:57 PM   #6
Ride:  '91 Civic hatch DX
Rep Power: 9 Exodus is off the scale
Send a message via ICQ to Exodus Send a message via AIM to Exodus Send a message via MSN to Exodus Send a message via Yahoo to Exodus
It feels too "idiots guide to tuning" for me, and the last thing I want is more idiots in the car scene. No thank you.
I didn't agree with a lot of the pricing and the upgrade structures. It was a lot more directed and focused then the way that a lot of people put their cars together for sure, but, as far as building a REAL car goes, not so much. It's not as simple as it's making it look by any stretch.
Exodus is offline   Reply With Quote
Old 01-27-2007, 10:41 PM   #7
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Eh, it's SuperHonda
H22 Swap Guide Luded HYBRID -> BA-BB /CA-CD 7 12-13-2006 02:57 AM
need performance parts!!!!! nkroberson Accord 1 11-02-2006 10:19 AM
Which Performance Upgrade? jasondw Engine Building 12 04-13-2006 09:04 AM
Help finding performance parts for '03 Accord V6? Omicron Engine Building 0 09-04-2003 07:57 PM
Performance Wise Modification? ovcrash Engine Building 18 04-23-2003 11:50 AM
