Block Guard Question
Old 10-19-2003, 04:54 PM   #1
Import King of Irvington
R.E.Developement's Avatar
Rep Power: 15 R.E.Developement is an unknown quantity at this point
Talking
i am looking to do a lsvtec turbo setup nothing big,just something to play around with and to get to point a to b in my 91 integra. the is what i have in mind right now
b18a block (i already have)
b16a head (i already have)
sir trans (i already have)
gsr oil pump
gsr water pump
gsr timing belt
new bearings
arp rod studs
arp head bolts
comptech turbo head gasket
aem fuel rail
aem fuel pressure regulator
440 injectors
vafc controller
dual stage boost controller
thats what i have in mind to do but ive heard that i can use a block guard also.
where would i get one from and how much will it cost
my team aint never scared cause we build seriousness.
forever Possessed Imports
R.E.Developement is offline   Reply With Quote
Old 10-22-2003, 08:47 PM   #2
Rep Power: 13 11sec. ALLMOTOR is off the scale
gsr oil pump
gsr water pump
gsr timing belt
new bearings
arp rod studs
arp head bolts
aem fuel rail
440 injectors
vafc controller
we carry Block guards made by JG or str $125 shipped in stock
Also have the RC 440cc $275 shipped in stock and we are a distri. for DRAG turbo kits
M-F 10am-6pm PST
Ben
Tech: (626) 363-1690
Fax: (626)363-1696
ProdigyWorks@aol.com
AIM: iC 8317
<a href=\'http://www.ProdigyWorks.com\' target=\'_blank\'>http://www.ProdigyWorks.com</a> Import Performance Parts and JDM motors&amp; Turbo parts
11sec. ALLMOTOR is offline   Reply With Quote
Old 10-22-2003, 09:02 PM   #3
i think you'll need to use the LS timing belt... that's what I was told to use, and that's what im using... Im doing LSVTEC also... I got the B16A1 head, gsr water pump and LS TB... got the B16 IM, and a Hedman Chikara Header... that's about it still looking for a crank rods adn pistons... and rings... damn though
90 Integra Sedan
B20V 225 / 153
Old 10-22-2003, 09:14 PM   #4
Banned
Rep Power: 0 Tonyd0821 is off the scale
Send a message via AIM to Tonyd0821
can i quote an internet rumor? (this way by saying it is a rumor, you fuckers cant flame me....)
but from my "d" series turbo board, i was under the impression that a block guard on a street car would do more damage than good. few peeps were saying it blocks the coolant flow etc.
anyone dispel this myth or?
Tonyd0821 is offline   Reply With Quote
Old 10-22-2003, 09:24 PM   #5
CRX_B16B's Avatar
Rep Power: 16 CRX_B16B is off the scale
insted of a block gaurd go for the Darton MID sleeves they seem like they would work good.
1990 civic STD Mini-Me swap and T3 HMT setup....
CRX_B16B is offline   Reply With Quote
Old 10-22-2003, 10:06 PM   #6
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
Timing belt and water pump need to be from the same engine. If you use GSR water pump you use GSR timing belt and vice versa.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 10-22-2003, 10:16 PM   #7
Rep Power: 13 kevs_92gsr is off the scale
If you want a block guard you can get them for $100 on optionsauto.com!!!
kevs_92gsr is offline   Reply With Quote
Old 10-28-2003, 05:15 PM   #8
Rep Power: 21 deth101 is off the scale
Send a message via MSN to deth101 Send a message via Yahoo to deth101
there is a reason block guards are $100......do it right and get a sleeve with a deck.golden eagle,or aebs would be good places to start looking
</span><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE </td></tr><tr><td id=\'QUOTE\'>QUOTE (pyrohardcore @ Apr 22 2003, 06:56 PM)guess i'm sorta out in the open surrounded by fat kids in paintball tho </td></tr></table><span class=\'signature\'>
Evil Should'nt Look This Good.
deth101 is offline   Reply With Quote
Old 10-28-2003, 10:05 PM   #9
Rep Power: 47 liquid00meth is off the scale
Send a message via AIM to liquid00meth
block guards are not even worth the 100$ unless your running like a NOS d series or some other ridiculously weak explosive motor
&quot;Our enemies are innovative and resourceful, and so are we.
They never stop thinking about new ways to harm our country and our people, and neither do we.&quot;
-The thought provoking George W. Bush
liquid00meth is offline   Reply With Quote
Old 10-29-2003, 10:38 AM   #10
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
do a search under my name in the FI forum for block gaurds. I've covered my opinions on this several times.
block guard? javenger Forced Induction 3 04-09-2004 05:40 AM
Question about building my block...? NeedACivic Forced Induction 3 12-01-2003 01:14 AM
question about a block guard bryan Engine Building 5 07-24-2003 07:23 PM
Sleeves Or Block Guard? b16ahatch Forced Induction 5 05-05-2003 02:42 AM
