Well, I have found some short blocks for sale but i'm undecided on which one to get... Question though, what other blocks can take the ls internals... I have heard of using ls cranks in gsr blocks (c-speed's 12sec integra) and once about using one in a b16 block. The blocks for sale are a 99 b16 block with bent rods but with no sleeve damage apparently, and a 95 ls block with bent rods also with no sleeve damage. he want about $125 for either block but im unsure if I can put my ls head on the b16 block and also what to check when it comes to damages in the block.
He also has a complete gsr block with eagle rods and je 10:1 pistons sleeved to 84.5 mm. He wants $1300 for that block but same question... can I put my ls head on that block... I have WAY to much work in that head to waste it plus I cant afford a new head. My original thread is here http://www.hondaswap.com/forums/index.php?...ST&f=13&t=15096 __________________
'Due to budget cuts, the light at the end of the tunnel has been turned off.' 'Out of my mind, back in five minutes' Originally posted by simba Canada didn't become a communist state, it became a socialist country run by liberal housewives who think cause and effect is black and white. Own a gun? Well, it's probably going to cause someone to be shot sooner or later. Better restrict them. Own a fast car? Well, you're probably going to kill someone due to driving too fast sooner or later. Better give the police unlimited power to "convince" you to return it to stock, so you won't kill anyone. Freedom is subjective. |
to get an LS crank and rods to work in a B16 you would have to do some major modification, probably add a deck plate because of the block height differences. if you're set on keeping that LS head, i'd just go for the LS block.
2005 Mitsubishi Lancer Evolution 8 2004 BMW 325i 2000 Mercedes Benz ML 430 1994 Honda Civic Del Sol VTEC (race kaa) |
Yeah, I figured as much, I just needed someone to confirm it for me... any tips on what to look for damagewise on the ls block with the bent rods?
just check the cylinder walls for any kind of scaring or scratches that you dont think can be honed out.
#5 |
thx... I am also going to rent a micrometer to check the evenness (sp?) of the bore... this is really a piss off since I have already finished building the other block completely... that and the other block I had was in PERFECT condition except for the threads. Factory crosshashing on the bores and everything... 32,000 km too
before the build.__________________
| ls/vtec werd | KWJaY | Engine Building | 11 | 09-10-2003 05:39 PM |
| Want A High Revving Monster? | maverick97 | Engine Building | 10 | 06-26-2003 04:25 PM |
| Swapping Gsr Block... | 1kleanTeg | Engine Building | 6 | 06-24-2003 03:11 AM |
| What is a short block / long block? | Calesta | General Tech Articles | 0 | 12-18-2002 08:27 PM |
