The boosted ls/vtec build is finished!
Old 08-26-2007, 01:35 PM   #1
Boosted ls/vtec ohh yeah!
boostin4fun's Avatar
Ride:  2000 Civic Si, 1995 Civic Ex auto to manual conversion
Rep Power: 14 boostin4fun has a spectacular aura aboutboostin4fun has a spectacular aura about
Default The boosted ls/vtec build is finished!
Engine:
b18b1 block bored .10 over and decked
LS crankshaft micropolished and balanced
Eagle ESP H beams
SRP 8.9 compression pistons with b16 head
Moroso 5.5 quart pan with pickup
All new type r oil and water pumps
CTR N1 crank pully
ARP headstuds
Endyn b series breather kit
All new factory Acura and Honda seals and gaskets
Head:
2000 civic si head
b16 intake manifold with Edelbrock type r 65mm throttle body port matched.
Hondata intake manifold spacer/gasket
New type r springs and retainers
New type r lost motion assemblies
JDM gsr camshafts
Ferrea stainless valves and locks
Fresh valve job and oem valve seals
Skunk2 proseries camgears
Chromed and cut type r valve cover
Type r oil cap
Greddy extreme t-belt
Turbo setup:
M.P.R.D. Equal length manifold
Turbonetics t3/t4 50 trim .48 ar
Greddy intercooler
Tial 38mm wastegate
Greddy type RS bov
Custom made 2.5" intercooler piping I made then painted concorde blue with dupont imron.
Custom made 3" dowpipe and catback exhaust with Apexi WS2 turbo muffler.
Drivetrain:
Integra LS tranny
Quaife ATB LSD
Exedy stage 2 cerametallic racing clutch
Exedy lightweight flywheel
Other things:
Koyo racing radiator
Spal push fan
Innovative mounts driver side mount, eliminates pussy fluid filled factory mount
Avid lower torque mounts, no such thing as engine movement after these!
Electronics:
Greddy 52mm boost and egt gauges
Greddy turbo timer
Apexi avcr boost controller
MSD 6al ignition with cap and blaster ss coil
GM 3 bar map sensor
Fuel management:
AEM fuel rail and regulator
B&M fuel pressur gauge
RC 750cc Saturated Injectors
Walbro 255lph fuel pump
Innovate lc1 wide band o2
Chipped p28 using CROME PRO
Moates ostrich, Burn1
Hondalog
I do swaps, engine builds, tuning, here in omaha. PM me for details. Do not PM me with tech questions, use the forums!!
All motor ls/vtec build
http://hondaswap.com/engine-building...53/#post791137
My 2000 civic si ls/vtec turbo build.
http://hondaswap.com/engine-building...05/#post861900
boostin4fun is offline   Reply With Quote
Old 08-26-2007, 01:42 PM   #2
These are some pictures of the electronics install, and the final product.
Old 08-26-2007, 01:50 PM   #3
Here are some pics of the car in rough stages of fabrication. It took some work to make the front mount fit as well as it does. I had to do some cutting on the radiator support as well as some welding of brackets.
Old 08-26-2007, 01:59 PM   #4
Here are some pics of the quaife install. This was the first quiafe I installed but it really wasnt too bad. The quiafe is an awesome unit. I cant believe the difference in cornering and traction it makes! I think it is one of the best upgrades for a boosted car period.
Old 08-26-2007, 02:03 PM   #5
HS RA
eg6sir's Avatar
Ride:  Le Car
Rep Power: 225 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace
nice build!! .. what kinda numbers you making?
that b16 manifold is holding you back a lot..
DO NOT PM ME WITH TECH QUESTIONS!
Originally Posted by Celerity View Post
Nothing says class like Willie Nelson on your pussy.
MY For Sale thread
eg6sir is online now   Reply With Quote
Old 08-26-2007, 02:07 PM   #6
Here are some shots after it was all done, waiting to be fired up for the very first time.
Old 08-26-2007, 02:10 PM   #7
HS RA
eg6sir's Avatar
Ride:  Le Car
you really need a better IM
MY For Sale thread
Old 08-26-2007, 02:21 PM   #8
This was crunch time right here. It was either make it or break it! I have never been so excited and nervous at the same time, it was the weirdest feeling I have ever had! The car fired right up after turning it over for 20 seconds or so several times to build oil pressure. I only had one leak. It turned out to be oil and it was leaking from the moroso pan. Moroso has a spot to add a oil temp sending unit, it comes factory installed on the pan. But they neither tighten it all the way or put teflon thread sealant on it. I put sealant on it and tightened it on my first oil change which was only 30 miles or so later. That took care of it. Right now I am only running 10lbs of boost with a rich tune of about 11.5 afr in boost. I also pulled out a degree of timing per pound of boost also. I currently have about 300 miles on it, it doesnt smoke or leak at all. I am waiting to get some more miles on it then I am going to add 2 to 4 lbs more and do some more tunning. Then I can finally burn a chip and get my ecu off the floor! Even on 10 lbs its quick! I get lsd wheel spin towards the end of 2nd with yokahama spec 2 on 17's. 2nd gear takes you to 65 at redline and it gets there like that! 3rd goes to 100 and is just as fun. The car came out how I had it pictured in my head all of this time. I cant wait to build another ass whooping machine like this one! If you have seen my other thread for the all motor ls/vtec build in the crx I will be updating it soon. That car is freaking amazing, just wait till you see the new pics I have. I dont have any power numbers yet. I have everything to tune properly. But my favorite tunning spot is gone now. The only dyno I will use is a mustang dyno and the only people in town that have one I dont like. But after I bring the boost up and get it tunned to where I want it I will make a couple power pulls at the dyno and post one up.
Old 04-10-2008, 06:02 PM   #9
Well I know that this thread is kind of old. But the other day I found pics of the engine build, I thought they were lost on the hardrive but unbelievably I got them back. So here is a few pics of when the motor was getting built, it was pretty.
Old 04-10-2008, 07:02 PM   #10
Here are some pics of the head. Ferrea valves and locks, type r springs and retainers, and a fresh valvejob with seals.
Old 04-10-2008, 07:04 PM   #11
Here are some pics of the short block and whatever else.
Old 04-10-2008, 07:09 PM   #12
Zoolander bitches
get_nick's Avatar
Ride:  '07 R6, sil-80 drift style
Rep Power: 194 get_nick has a reputation beyond reputeget_nick has a reputation beyond repute
get_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond repute
congrats on the build.
Explains my life to a "T"...
God damn it, an entire generation pumping gas, waiting tables; slaves with white collars. Advertising has us chasing cars and clothes, working jobs we hate so we can buy shit we don't need. Our Great War's a spiritual war... our Great Depression is our lives. We've all been raised on television to believe that one day we'd all be millionaires, and movie gods, and rock stars. But we won't. And we're slowly learning that fact. And we're very, very pissed off.
get_nick is offline   Reply With Quote
Old 04-10-2008, 07:11 PM   #13
A little farther along.
Old 04-10-2008, 07:24 PM   #14
A nice shot
Old 04-10-2008, 08:40 PM   #15
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 121 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
How have those IC pipes held up. I see you welded a bracket to the frame. That's going to give you trouble down the road. You should have just left it alone so it can flex. Other than that....it looks great. Get us a video,
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
=I love this truck
2007 Civic
=Not sure what the future holds for this
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 04-10-2008, 08:46 PM   #16
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 40 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
I wanna see video footage as well. Can't wait til I finish my hatch. 300whp on the street is so much funnnn.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 04-10-2008, 10:29 PM   #17
The intercooler piping has held up with zero problems. I have mostly urethane mounts including the avid urethane torque mounts. Drivetrain movement is basically non existant, my dash rattles pretty good. The bracket keeps the pipe centered in the opening so it is not rub up against the car causing problems.
Old 04-11-2008, 12:51 AM   #18
The name's Sam
philyphreak2127's Avatar
Ride:  98 civic dx sedan, 80 trans am
Rep Power: 18 philyphreak2127 will become famous soon enough
sick build. But he is right get yourself a new intake manifold it will open up your motor a little more. at least go with the type-r IM if anything.
philyphreak2127 is offline   Reply With Quote
Old 04-11-2008, 07:48 AM   #19
I didnt get the car finished to late last summer so I have a few things I want to do with it now. I am getting a new manifold, probably this peakboost manifold that I like. I am also going to get a different intake manifold and do a 3 inch exhaust all the way back. Right now I only have a 2.5" downpipe connected to greddy evo2 exhaust. So that will really help it breath more. I am also considering a slightly smaller intercooler but it does fill pretty quickly with the specs on the turbo.
