#26 |
Boosted ls/vtec ohh yeah!
Ride: 2000 Civic Si, 1995 Civic Ex auto to manual conversion
Here are some updated pictures with the new manifold and exhaust.
I do swaps, engine builds, tuning, here in omaha. PM me for details. Do not PM me with tech questions, use the forums!! All motor ls/vtec build http://hondaswap.com/engine-building...53/#post791137 My 2000 civic si ls/vtec turbo build. http://hondaswap.com/engine-building...05/#post861900 |
#27 |
The bigger exhaust significantly leaned out my old map. I have drove it for about 100 miles since the work and have a pretty good street tune on it right now. It is between 11.2-12 AFR in boost all the way to red line. It pulls way harder then it did before. I dont know what kind of numbers I am making but very likely 300whp because I am already at a pretty high injector duty cycle with 650s. I am running about 12psi and I am thinking of going for 14 or 15 and getting some 750cc injectors. But then again I am pretty happy with it right now!
#28 | ||
Honda Enthusiast
Ride: '94 EG sedan w /Z6, '97 EK hatch
You're a great inspiration man. Great job.
Max? There is no max. Max just means you gave up. This is my thread: http://hondaswap.com/engine-building...g-wind-110848/ My for sale/trade thread http://hondaswap.com/parts-sale-trad...1/#post1048406 Quote:
#29 |
I am glad you like the build. I need to come up with a camcorder so I can get some video footage up. Maybe I can talk my sister into letting me borrow hers.
#30 |
kid that everyone loves!
Ride: 91 accrod DX with a few extras : )
nice build i only wish i new half as much as u do about hondas man
heres my mod. list ![]() -painted valve cover -new headers -new high flow obx resonator -new carbon fiber exaust tip -new p.s pump -new radiator -new belt -new injen ram intake -new strut bar -new deck (installed myself) -new speakers -not bad for learning as i went and not having shit for help besides u great guys i think thats around all i did, tok a few months but im happy with it! and after all that theres a small puddle of oil under my intake on my engine..... the fun never ends! |
#31 |
Yep I definetly outgrew the 650cc injectors I was running. I was at almost 50 psi of fuel pressure with 90% or slightly higher duty cycle. So I put in some 750s and turned the fuel pressure back down to 44psi. Duty cycle has gone done quite a bit so I feel alot safer.
#33 |
You can do it several different ways. Some people like to buy the sandwich plate that allows you to run lines from it. If you want to go that route I would get this sandwich plate because it is afforadable and well designed Generic Oil Plumbing Kit On my setup I have a t-fitting installed where the oil pressure sending unit is, that is where I ran a line for the vtec conversion. There is another plug in the head right by the water neck that is brass colored or maybe it is brass anyways, I ran a fitting from there to supply oil for the turbo. I have had this setup together for sometime now with absolutely zero oiling problems. Either option will work well.
#34 |
you get the BRAKE
Niceeeee... I love me some el es veetech!
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
| Boosted ls/vtec crank | blackz151 | Engine Building | 20 | 08-28-2007 09:38 AM |
| ls/vtec all motor build ? | ek4me | Engine Building | 1 | 06-04-2007 09:41 PM |
| my ls/vtec build | ls/vtechatch91 | Civic and CRX - EF | 8 | 04-11-2007 02:59 PM |
| LS/vtec Boosted vs LS boosted | BoostedEG/LS | Forced Induction | 6 | 02-08-2007 09:45 PM |
| finally finished the build up | CrazyAzn | Auto Multi-Media | 24 | 08-22-2006 12:59 AM |
