Boosting a Type R engine
Old 10-23-2003, 04:28 PM   #1
Rep Power: 0 TYPE-R-RACER is off the scale
Unhappy
My question is, Is it possible to boost a stock Type R with stock internals. If this is possible what would be the most psi you would be able to push out of the engine. This question may seem dumb but i only ask it because im going to buy a Type R motor preatty soon and i read on the following Super Street article http://www.superstreetonline.com/featuredv...vehicles/30478/ and this guys running a Type R turbo set up on stock internals and hes making 328.5 hp at 8,400 rpm with 208.8 lb-ft.
TYPE-R-RACER is offline   Reply With Quote
Old 10-23-2003, 05:25 PM   #2
B16
B16's Avatar
of course its possible, but is it a good idea?
why not save the money you spend on the R motor and buy a GSR to boost?
it is a waste of money to boost an R.
how much PSI depends on turbo, tuner, fuel.
2004 BMW 325i
2000 Mercedes Benz ML 430
Old 10-23-2003, 05:30 PM   #3
Ride:  2006 Audi A4
Rep Power: 115 totalburnout has a brilliant future
totalburnout has a brilliant futuretotalburnout has a brilliant future
Send a message via AIM to totalburnout
why is it a waste of money to boost a R?
"Good talk... I'll see you out there."
totalburnout is offline   Reply With Quote
Old 10-23-2003, 05:56 PM   #4
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
I don't think it is so much a waste to boost it, as it would be to replace the internals to run higher boost. MOst people start on a lower compression ratio, and with cams that don't overlap, lift and have the duration that ITR's do. It makes it easier to tune, and you can run higher PSI. It is a waste to buy an ITR and then replace all the stuff that makes it an ITR, but you can boost a stock one. Colorpros on here has a ITRT, you can PM him and check his set up.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 10-23-2003, 05:57 PM   #5
B16
B16's Avatar
Originally posted by New2TheCarScene+Oct 23 2003, 01:30 PM--><div class='quotetop'>QUOTE(New2TheCarSc ene @ Oct 23 2003, 01:30 PM)</div><div class='quotemain'> <!--QuoteBegin-B16@Oct 23 2003, 04:25 PM
why is it a waste of money to boost a R? [/b][/quote]
why?
because the CR on an R is 11.1:1, GSR is 10.0:1
the cams on the R have more overlap, which means you will loose boost.
and because the R costs much more than the GSR, this makes it a waste.
2004 BMW 325i
Old 10-23-2003, 08:26 PM   #6
lots of pro drivers run 10.5:1 compression on their crazy boosted civics out there, what about a B18c5 with crower rods and JE pistons.
I say the cams are the most that I would go concerning overlapp, B will differ
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 10-23-2003, 09:23 PM   #7
B16
B16's Avatar
you are still pulling most of the Type R components out of the block.
2004 BMW 325i
WTB: GSR or Type R Engine projectxspeed Parts: For Sale/Trade/Wanted 1 02-23-2004 06:14 PM
Honda Engine List pissedoffsol Reference Materials 0 01-12-2004 02:51 AM
Engine Removal Guide pissedoffsol Swap Articles 0 01-12-2004 02:19 AM
HELP! d16y8 into my 92 Si civic_rider HYBRID -> EG-EK / DC 5 01-01-2004 11:16 AM
Need Help Identyfying Engine Type DSM TUNER General Tech and Maintenance 2 05-11-2003 05:26 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
