I just got my block back and a few misc. parts so now its time to put it all together again. Maybe this should be in multimedia? But I plan on doing maybe a little writeup of the build process to help provide a little info. Build list:
HEAD PR3 casting JUN III cams Golden Eagle cam gears Portflow port and polish and 3angle valve job Portflow inners type R outers Titanium retainers Bronze valve guides New rocker arms JG "sheetmetal" intake w/70mm RPM service throttle body RC 440 injectors GE fuel rail Walbro fuel pump ARC intake BLOCK B16b sleeved to 85mm by Benson's GSR crank balanced and micropolished by Benson's Probe I beam rods CP 8.1cc strutted pistons 12.5:1 compression Rage 4-2-1 header ITR trans with 4.78 final drive Hondata s200, plxm300 wideband o2 Last year at 81mm with a crap ebay header and stock manifold I put down 208whp and 140ft/lbs. I'm hoping for 240 and 160 this year, we will see!!! I should have it together within the week, I'll post up more pics as I go along. Here are some to get started. ![]() __________________
97 ex coupe Wire tuck in progress.... Last edited by 97CTR; 06-19-2006 at 08:17 AM. |
Hi everyone.Looking for any help tuning a european spec Honda HR-V 4x4 fitted with a D16W1 engine.Possible head swops,ecu swops.????? any help appreciated.thanks.
#5 | |
RETIRED
#8 |
I got my my ARP main studs the other day so I put the crank in and made sure all of my bearing clearances were on.
I first chased all of the mains with the appropriate tap and cleaned with compressed air. ![]() Next I cleaned the journals of the crank with some brake clean. Because as many of you may know, when building an engine you can never have anything too clean. ![]() I put the crank in the the block, lubed up my main studs and torqued down the main caps to check the clearances with plastigauge. ![]() ![]() ![]() Bearing clearances all came out to .015" right where I wanted them. And yes the engine is in my custom "clean room" aka the kitchen. Tomorrow I think I will do the rod bearings, size the rings and get the pistons installed. That is if I get the brakes done on my old lady's eclipse (so I can get it sold) and fix the suspension on my beater 96 hatch. __________________
97 ex coupe Wire tuck in progress.... Last edited by 97CTR; 06-22-2006 at 04:53 PM. |
#9 | |
did you have the main journals on the block resized for the arp studs? and is the tap a bottoming tap? or just a regular tap?
91 CRX si 95 Integra LS I DO NOT answer tech questions via PM. Use the forums!!! Quote:
get a free flatscreen, yes it works! Please give what you can to the Tom Cote Medical Fund http://honda-tech.com/zerothread/1828476 |
#10 |
No, I didn't have the mains align bored. I did torque the bridge and caps down with the studs and used my dial bore gauge and checked them for out of round and diameter and they were all still good. I used the same color bearings with the same crank I had last year and all of the clearances still matched those that I had recorded last year so its all good. But you are right, ARP does recomend that you get the mains align bored when you change to their studs. Because of clamping force and what not.
I've had this motor for over three years now, and I blueprinted it last year. So we know each other well ![]() __________________
97 ex coupe Wire tuck in progress.... Last edited by 97CTR; 06-23-2006 at 12:45 AM. |
#13 |
the type R outer springs able to take the lift of the JUN cams?
Looking good btw. That block is sexy as hell. __________________
2005 Mitsubishi Lancer Evolution 8 2004 BMW 325i 2000 Mercedes Benz ML 430 1994 Honda Civic Del Sol VTEC (race kaa) Last edited by B16; 07-20-2006 at 09:03 PM. |
#14 |
Portflow outers, type r inners. Going slow right now, just got my pistons coated and I have been away on vacation for the past two weeks. Will start the final assembly sometime this week.
97 ex coupe Wire tuck in progress.... |
#15 |
Got my ceramic coated pistons back this week. So I sized my rings and mounted the pistons on the rods. Should be good to go in a week or so. I'll keep postin pics as I go along.
![]() ![]() ![]() ![]() ![]() __________________
#18 | |
I wear stretchy pants
Ride: chevy s-10
nice man, keep it up!!!!!!!!!!
#19 |
![]() ![]() ![]() Finally got around to putting the rods and pistons in. Its pretty much all gravy from here on out. Hopefully I can have it in and running in two weeks time. __________________
#20 |
HS Troll...And Mod
Ride: 2001 Honda S2000
looks good. pimp tizight.
If you PM me with tech questions, you better have a link to the thread in your PM. Anime Informant |
#21 |
Admin with a big stick
Ride: 2003 S2000
Super cool. Those pistons look just like mine. I love them!
#22 |
HS Troll...And Mod
ut oh, calesta's up *cracks knuckles*
| b16b head | 96IntegGSR | HYBRID -> EG-EK / DC | 6 | 12-06-2006 07:55 AM |
| Del Sol Build Up Swap Options | Jamarquis | HYBRID -> EG-EK / DC | 4 | 07-14-2004 03:20 PM |
| B16B stroker | CRX_B16B | Engine Building | 28 | 10-22-2003 01:37 AM |
| Dyno chart for my new engine build | Calesta | Engine Building | 36 | 09-18-2003 03:23 PM |
| Build My Junkyard/hm Turbo Kit! | liquid00meth | Forced Induction | 7 | 05-02-2003 01:55 PM |
