Cam gears?
Old 08-02-2008, 09:45 AM   #1
The Hondaswap Canadian
Justin66's Avatar
Ride:  1990 Intergra GS/XSi
Rep Power: 27 Justin66 is a splendid one to beholdJustin66 is a splendid one to beholdJustin66 is a splendid one to beholdJustin66 is a splendid one to beholdJustin66 is a splendid one to beholdJustin66 is a splendid one to behold
Default Cam gears?
I just bought Skunk2 stage 1 tuner cams, mainly cause i have a limited budget especially to buy and install springs and retainers (not that i dont want to). I was wondering if it would be benificial to also buy their adjustable cam gears as well. Being lighter weight would help and would be easier to time, but would it be worth it for stage 1's? I dont have a problem with buying them but i just wanna know if its a waste or not?
90 Integra GS/ XSi
- JDM B16A SiR2 w/ full exhaust & short ram
- J1 Tranny
- Skunk2 stage 1 cams & gears (not installed yet)
- H & R lowering springs
- Rear strut bar and front camber kit
- HKS Hi-Power exhaust
- Powersteering removed
- JDM 1-piece headlights & sidemarkers
- Optima RedT relocated to rear
XBOX LIVE: JustinE66
Justin66 is offline   Reply With Quote
Old 08-02-2008, 10:55 AM   #2
jdm spec
Ride:  da9
Rep Power: 0 carlo is on a distinguished road
Send a message via MSN to carlo
even with stock cams its good to have acg to well tune your engine and squiz some ponys out of it
carlo is offline   Reply With Quote
Old 08-02-2008, 11:03 AM   #3
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 265 Calesta is a splendid one to beholdCalesta is a splendid one to beholdCalesta is a splendid one to beholdCalesta is a splendid one to beholdCalesta is a splendid one to beholdCalesta is a splendid one to behold
Yes, it's a good idea to get adjustable gears. You won't really see gains on a stock setup, but with aftermarket cams and a tune, you'll see a world of difference.
Old 08-02-2008, 01:09 PM   #4
Justin66's Avatar
Got ya. Since its N/A keeping matched with the same brand is a good idea. Match the skunk2 cams with skunk2 gears?
90 Integra GS/ XSi
- J1 Tranny
Old 08-02-2008, 06:10 PM   #5
Calesta's Avatar
Ride:  2003 S2000
Actually, it doesn't really matter. There's no reason to keep everything "matching" for functionality's sake- it's all vanity. Skunk2 does make good cam gears though.
Old 08-02-2008, 06:13 PM   #6
Justin66's Avatar
I have heard that, but also ive heard good and bad about their cams, researching it and they seem great. They are in alot of magazines like Modified and they are reliable. Some have told me they fail or break all the time.
90 Integra GS/ XSi
- J1 Tranny
Old 08-03-2008, 04:16 AM   #7
Calesta's Avatar
Ride:  2003 S2000
You have to take that with a grain of salt. Improper installation, bad parts combination, bad tuning... it can all make a specific part seem bad when it really isn't.
Old 08-03-2008, 04:20 AM   #8
My name is Byron.
efhondakid's Avatar
Ride:  `89 DX Hatch w/JDM B16
Rep Power: 101 efhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Any aftermarket cam should come with a spec sheet that tells you what gears should be advanced/retarded to to get the most out of the cams.
Looking for a P28 and B-series turbo parts, PM me.
Old 08-03-2008, 12:30 PM   #9
jdm spec
Ride:  da9
go dyno man thats the way you will know for sure and get an ecu to mess with your maps if you are not sure how to do it get a pro the help you thats the way to go
Old 08-03-2008, 12:36 PM   #10
jdm spec
Ride:  da9
personal i`ll go with blox or just get itr internals they are high lift cams and they have dual spring its a pretty good set-up ooohhh and get the itr v-tec solenoid to hear scream that thing
Old 08-03-2008, 03:14 PM   #11
Justin66's Avatar
What would the solenoid change, i figured all the dohc vtec engines had the same solenoids?
90 Integra GS/ XSi
- J1 Tranny
Old 08-03-2008, 03:38 PM   #12
Calesta's Avatar
Ride:  2003 S2000
Yes, they all need a normal VTEC solenoid to activate VTEC. There's no difference between them. An ITR solenoid won't do anything different for you than any other VTEC solenoid.
Old 08-03-2008, 05:27 PM   #13
The Kicker of Elves.
Blanco's Avatar
Rep Power: 217 Blanco has a reputation beyond repute
Blanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond repute
There's no point in buying aftermarket cams if you aren't going to tune them and there's no way to tune them without adjustable cam gears. They aren't a bunch of individual pieces, they all interrelate like pieces of a puzzle.
Keeping things the same brand applies mostly to cams and valve springs. The reason is that a manufacturer's valve springs are already matched to their cams. You can use any reputable brand combination you want as long as the valve springs have the proper seat pressure. Too little means you'll float a valve because of coil bind and blow up your engine. Too much pressure means that the cams will have to work harder to open the valves which leads to increased wear and tear and often times a broken cam shaft...which completely destroys the entire engine.
Here are the basics: HowStuffWorks "Internal Combustion"
Don't misinterpret what I say.
Originally Posted by The Secrets of Body Language
93% of communication is done through body language.
Originally Posted by http://humanresources.about.com/od/interpersonalcommunicatio1/a/nonverbal_com.htm
One study at UCLA indicated that up to 93 percent of communication effectiveness is determined by nonverbal cues. Another study indicated that the impact of a performance was determined 7 percent by the words used, 38 percent by voice quality, and 55 percent by the nonverbal communication.
Originally Posted by Shawn Pelton
It's not good to be a drummer unless you got some bad motherfucker up inside you.
Blanco is offline   Reply With Quote
Old 08-03-2008, 07:37 PM   #14
Justin66's Avatar
Makes sense. Ill get the gears, it was my plan anyway. Since i wont be using aftermarket springs or retainers is there any big risk to using this cam? Again i wont be taking the car any past 8k anyway and its still the stock rev limiter, the springs can handle it?
90 Integra GS/ XSi
- J1 Tranny
Old 08-03-2008, 07:44 PM   #15
Blanco's Avatar
Don't rev over the stock limit until you at least get ITR springs and you'll be fine.
Old 08-03-2008, 07:48 PM   #16
Justin66's Avatar
Ok thanks Blanco its keeping my paranoia down. I dont take the car past 8k at anytime really, Unless im not paying attention. Cam gears will be on the way soon.
90 Integra GS/ XSi
- J1 Tranny
Old 08-06-2008, 01:46 PM   #17
jdm spec
Ride:  da9
hey about the dolenoide dont ask way but itr intrnals in your b16 head screams for some reason like i said its a good set up it maches your stage 1 cams and they are stock
Old 08-06-2008, 06:35 PM   #18
Justin66's Avatar
If i ever have to do a head gasket change ill be sure to get itr springs, something to better keep up. Other than these cams i dont intend on anymore internals. Maybe a rail+injectors, TB, now that i have cams. Better rad (fins starting to flake off), maybe new intake manifold. Should be good now. Then the rest is to maintain the car. Just a nice high flowing B16.
90 Integra GS/ XSi
- J1 Tranny
Old 08-06-2008, 07:59 PM   #19
Blanco's Avatar
Carlo, please know what you're talking about before you give advice.
If you plan on changing the springs anyway, you might as well get aftermarket springs for your aftermarket cams. Changing the solenoid won't do anything for performance unless the one on your engine isn't working properly. You don't even remotely need a new fuel rail or injectors for your goals...unless you're replacing worn out OEM units with new OEM units. If you want an aftermarket intake manifold, Skunk2 is going to be your best bet other than the ITR manifold it was designed after.
Old 08-06-2008, 10:21 PM   #20
Justin66's Avatar
Ya i was lookin at Skunk2 for the mani. Since the fuel wont seem to help any will a TB help?
90 Integra GS/ XSi
- J1 Tranny
Old 08-06-2008, 10:27 PM   #21
Calesta's Avatar
Ride:  2003 S2000
Not much.
Old 08-07-2008, 12:52 AM   #22
Blanco's Avatar
