Cam gears?
Old 08-07-2008, 08:08 AM   #26
Von Europa
awptickes's Avatar
Ride:  1999 Civic EJ9, 2003 Civic EX Coupé
Rep Power: 55 awptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant futureawptickes has a brilliant future
Has it been tuned professionally? Take it to a tuner and tell them what the problem is. You'd be suprised how big of a difference a good tune can make.
awptickes is offline   Reply With Quote
Old 08-07-2008, 08:15 AM   #27
The Hondaswap Canadian
Justin66's Avatar
Ride:  1990 Intergra GS/XSi
Rep Power: 27 Justin66 is a splendid one to beholdJustin66 is a splendid one to beholdJustin66 is a splendid one to beholdJustin66 is a splendid one to beholdJustin66 is a splendid one to beholdJustin66 is a splendid one to behold
The cams arnt in yet, and no it hasent been tuned, im still looking for a place around here, chances are ill have to take a trip to Toronto sometime. Anything else?
90 Integra GS/ XSi
- JDM B16A SiR2 w/ full exhaust & short ram
- J1 Tranny
- Skunk2 stage 1 cams & gears (not installed yet)
- H & R lowering springs
- Rear strut bar and front camber kit
- HKS Hi-Power exhaust
- Powersteering removed
- JDM 1-piece headlights & sidemarkers
- Optima RedT relocated to rear
XBOX LIVE: JustinE66
Justin66 is offline   Reply With Quote
Old 08-07-2008, 08:41 AM   #28
I still know everything
caboose's Avatar
Ride:  89 CRX HF, 96 Accord EX, 88 Dodge Daytona Shelbyz T-tops
Rep Power: 6 caboose will become famous soon enoughcaboose will become famous soon enough
Underdrive pulley, aluminum flywheel, header/catback ( if you are looking to increase top end).
Underdrive will only free up a few ponies, but with that, adj cam gears, and al flywheel, you will save a lot of weight on your rotating mass
Formerly the.original.kermit
Back from the dead...
twice
I NEED PARTS!!!
http://hondaswap.com/parts-sale-trade-wanted/wtb-1989-crx-parts-161172/#post1079066
Check out my progress...
http://hondaswap.com/auto-multi-media/my-1989-crx-project-144941/
caboose is offline   Reply With Quote
Old 08-07-2008, 08:45 AM   #29
Von Europa
awptickes's Avatar
Rotational mass only helps when you had torque there to begin with.
Old 08-07-2008, 08:51 AM   #30
caboose's Avatar
Actually imo if you have less torque, you will see the benefits of the light weight more, as you already have less torque to begin with, so every bit that you lose to the fw is a larger percentage.... if that makes sense.
Also you will see MUCH better engine response
twice
I NEED PARTS!!!
Old 08-07-2008, 05:01 PM   #31
Justin66's Avatar
Yes thank you i realize its a 1.6, what do you want from me?
Ill look into the underdrive pullies. I will be getting the adj gears. A light flywheel will be nice. Ill try to knock off some weight out of my car, including my weight . Thanks caboose, ha ha everytime i see your name i think of Red Vs Blue.
90 Integra GS/ XSi
- J1 Tranny
Old 08-07-2008, 06:09 PM   #32
caboose's Avatar
Where do you think it came from!, LOL... happy someone noticed. My xbl name is actually fear caboose 1.
I picked it because I tend to be a little grenade happy at times and kill teammates, so i figured it was fitting.
twice
I NEED PARTS!!!
Old 08-07-2008, 08:01 PM   #33
Justin66's Avatar
Ya i know all about the team killing grenades, sexy
90 Integra GS/ XSi
- J1 Tranny
Old 08-07-2008, 08:19 PM   #34
The Kicker of Elves.
Blanco's Avatar
Rep Power: 217 Blanco has a reputation beyond repute
Blanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond repute
Don't use under drive pulleys on a street car unless you like replacing your accessories. And never use an aftermarket crank pulley on a Honda, use a CTR N1.
Don't misinterpret what I say.
Originally Posted by The Secrets of Body Language
93% of communication is done through body language.
Originally Posted by http://humanresources.about.com/od/interpersonalcommunicatio1/a/nonverbal_com.htm
One study at UCLA indicated that up to 93 percent of communication effectiveness is determined by nonverbal cues. Another study indicated that the impact of a performance was determined 7 percent by the words used, 38 percent by voice quality, and 55 percent by the nonverbal communication.
Originally Posted by Shawn Pelton
It's not good to be a drummer unless you got some bad motherfucker up inside you.
Blanco is offline   Reply With Quote
Old 08-07-2008, 08:21 PM   #35
caboose's Avatar
actually my little icon above my halo guy is the grenade, lol
can't say i didn't warn them
twice
I NEED PARTS!!!
Old 08-07-2008, 08:22 PM   #36
caboose's Avatar
Under drive pulleys save accessories
I have a aftermarket crank pulley too
twice
I NEED PARTS!!!
Old 08-07-2008, 08:23 PM   #37
Blanco's Avatar
Not on Hondas.
Old 08-07-2008, 08:26 PM   #38
caboose's Avatar
how do you figure
twice
I NEED PARTS!!!
Old 08-07-2008, 08:34 PM   #39
Blanco's Avatar
Um, six years of seeing people with underdrive pulleys have burned up alternators? It doesn't take a genius to figure out that fire's hot.
Old 08-07-2008, 10:05 PM   #40
Justin66's Avatar
Sorry whats CTR N1?
90 Integra GS/ XSi
- J1 Tranny
Old 08-07-2008, 10:45 PM   #41
Blanco's Avatar
Civic Type R N1 racing pulley. It only has room for the alternator belt and is essentially an OEM lightweight crank pulley.
Old 08-07-2008, 11:49 PM   #42
El Sam
94H_Ex's Avatar
Ride:  94' Honda Civic Ex. (under construction)
Rep Power: 6 94H_Ex has a spectacular aura about94H_Ex has a spectacular aura about
Send a message via AIM to 94H_Ex myspace
Anything else i can do to get more power? (Please no smart ass comments like TURBO or STAGE 3 CAMS!)
Nitrous. shoot for a direct port nitrous system. I hear their the safest kit there is right now. correct me if im wrong. if not run with a 75 wet shot.
Originally Posted by Luis998 View Post
You're a bastard. haha
For Sale Thread
http://hondaswap.com/parts-sale-trad...b-list-157320/
^^^^updated
94H_Ex is offline   Reply With Quote
Old 08-08-2008, 04:59 PM   #43
Justin66's Avatar
Well its an option but im not a fan of it nor the temporary horsepower, but i thats one none the less.
90 Integra GS/ XSi
- J1 Tranny
Forum Jump
Cam gears efhondakid Engine Building
