Im torn between the AEM cam gears and the Spoon, which are better? Any other cam gears that provide the best result, $$$ not an issue.
T3T67 ![]() <a href=\"http://www.hondaswap.com/forums/index.php?showtopic=69573\" target=\"_blank\">Buy my MSD 6AL, Carsound Cat, VTEC Distributor!</a> <a href=\"http://ipods.freepay.com/?r=11169222\" target=\"_blank\">Sign up for a Free Ipod!</a> |
anything other than aem
aem have only 3 bolts and could slip.
11th world conference on titanium |
#3 | |
Member of the 20 nut club
dont bother wasting your time or money on the AEM's
1st off, for what application? if it's B series, you got more (better) options.
My skin is singed but it heals my heart and with glowing pride I'll wear my scars. I'm honored by your hatred! She wanted love, I taste of blood. She bit my lip and drank my warmth from years before. |
#5 |
here's my experience with cam gears...
spoon/toda are badass...as you get what you pay for! now, skunk2 gears work well, although under extreme conditions the gears can sometimes expand, causing the timing belt to become tighter and this can cause a motor to seize, bad!!!!!!!!!! but this is in rare conditions, and unlikely to happen, although i'd check the tension of your timing belt from time to time... aem gears...yes i worry about them slipping, however when torqued correctly they can be reliable... for a daily driven setup i'd go with skunk2 gears. personally, i'm going with toda cam gears when i have the money, of course there are others out there including endyn and str which are also supposed to be good. i can't comment on these, because i've never used them.
<a href=\'http://www.geocities.com/coker_boy/honda.html\' target=\'_blank\'>The Green Machine</a> |
#9 |
#10 |
Guest
Jun,Toda,Spoon
#11 | |
RETIRED
#12 |
just another factor, u want ones that utilize or have the same "teeth" as the OEM cam gear.
Toda works for me btw
Used performance parts straight from Japan/road race questions: <a href=\'http://www.rcrewracing.com\' target=\'_blank\'>www.rcrewracing.c om</a> |
#14 | |
the only issue with the skunk2s is that the bolt heads can strip if your not careful .... you shouldnt really be fucking with them all the time any way though ... just get it tuned ... set em and forget em... or replace the bolts with better ones
#16 |
I got a B18CR, i dont care for price, which is the absolute best? JUN, Spoon, Toda, Skunk2?
#17 | |
Toda
#19 | |
| No 4th or reverse gears in tranny | mrvanparys | HYBRID -> EG-EK / DC | 11 | 01-05-2008 09:01 PM |
| B Series Cam Guide | JDMilan | Reference Materials | 35 | 04-13-2007 09:26 PM |
| How to: Adjusting Cam Gears | pissedoffsol | General Tech Articles | 0 | 01-12-2004 01:49 AM |
| need cam gears??? | mattcalica | Engine Building | 4 | 07-04-2003 05:26 AM |
| Are My Cam Gears Off Centered? 2 Pics Inside! I | Hybrid93Hatch | General Tech and Maintenance | 0 | 03-25-2003 08:53 AM |
