Cams and cam Gears
Old 01-22-2004, 11:18 AM   #1
Rep Power: 18 khai_tuan_nguyen is off the scale
Hi guys.
I have a 97 hx coupe. I swapped in a b20 vtec. I just bought a fuel pressure regulator and a 255 lph fuel pump. I have je 12:1 pistons and the head has dual valve springs and they have been worked on for higher revs. I am goign to get obd2-1 and hondata s100. Then i am going to dyno tune. Since dyno tuning is expensive, what else do you guys recommend before i dyno tune it. I was looking at cams and cam gears? Any recommendations?
Once it is dynotuned i am done with the build.
Thanks
Khai
<a href=\'http://www.hondaswap.com/forums/index.php?act=module&module=gallery &cmd=user&user=25607&op=view_album& album=107\' target=\'_blank\'>PICTURES: Type R Stuff/ B-Series Parts for Sale</a>
khai_tuan_nguyen is offline   Reply With Quote
Old 01-22-2004, 02:22 PM   #2
any ideas?
Old 01-22-2004, 02:33 PM   #3
Rep Power: 24 SolPWR is off the scale
Send a message via AIM to SolPWR Send a message via MSN to SolPWR Send a message via Yahoo to SolPWR
cams I like Unorthodox Racing 5 bolt, as far as cams not to sure about the B-series but I like the ZEX cam for the D's, they might have these for the B's as well. I would also look into the skunk2's but I heard they have a rough idle.
Sold my sol to the devil!!! not really just a friend who thinks hes the devil
Now driving Suzi, My 05 Suzuki Aerio SX
SolPWR is offline   Reply With Quote
Old 01-22-2004, 03:14 PM   #4
Banned
Rep Power: 0 B18C_NA is off the scale
AEM gears w/ CTR or ITR, good for daily driven, but if you want to take another step, try skunk2 stage 2, JUN or Toda Spec A. You'll be thrilled. Be sure to degree when you install. header and exhaust could do too.
B18C_NA is offline   Reply With Quote
Old 01-22-2004, 03:41 PM   #5
what do you mean degree when i install? I have header and exhaust. It will be a daily driver. So what recommendations do you guys recommend now. I really want to feel that vtec.
thanks
Khai
Old 01-23-2004, 06:58 PM   #6
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 288 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
Toda C. Wait, that's what I'm going to run. Oops.
Old 01-26-2004, 12:39 PM   #7
what are the differences between toda spec A,B and C. I want a daily driver, with a serious vtec kick. I want smooth low idle. Also isn't there something about clearance issues with any of these cams? What other mods should i do before i dynotune?
Thanks
KHai
PS where can i find these cams for a good price?
Old 01-26-2004, 09:53 PM   #8
there is a cam guide by "me" upstairs, check it out.
CamGears suggestions would be any cam gear with alteast 4 bolt pattern and CANNOT be adjusted for more than +/- 5 degrees, I recommend Spoon cam gears
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 01-27-2004, 03:42 PM   #9
thanks for the cam guide milan. Now I need to find a good place to buy the cams. Also will i have a problem with lift on my cams, I don't want anything hitting anything else?
Thanks again
Khai
Old 01-28-2004, 11:22 AM   #10
Any Ideas?
Old 01-30-2004, 06:56 PM   #11
Old 01-30-2004, 07:06 PM   #12
try thee ZEX cams. Heard they are really good.
Check it out
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
