clutch slave cylinder
Old 05-09-2008, 11:11 AM   #1
bigg86 is an unknown quantity at this point
Default clutch slave cylinder
is there any after market clutch slave cylinders for b-series engines running high HP???? i already upgraded the master cylinder to one that is almost twice the size of the stock one, but since i'm getting a 487 torque capacity pressure plate (ACT part # AI4-XXG6) i believe i need to upgrade my slave cylinder as well to help out my hydraulic system...
P/S: i'm planning to run 450-550whp
bigg86 is offline   Reply With Quote
Old 05-10-2008, 02:29 AM   #2
BrokenRex has a spectacular aura aboutBrokenRex has a spectacular aura aboutBrokenRex has a spectacular aura about
I'm not aware of one being available. however with a larger slave cylinder, the pedal will be harder, but travel less distance. the harder pedal from the larger slave cylinder with a pressure plate capable of holding 550whp is going to make a hell of a hard pedal. if you say to yourself "well shit, then why not use a smaller cylinder?" because there's only so much travel in there. if the clutch has a small window of engagement then you might be able to get away with this, however if it's got some slip in it, your smaller cylinder might not move enough fluid to fully disengage the clutch. or worse, to not fully engage it. stick with the stock cylinder and research the available clutch pressure plates. you might be able to get away with using a more aggressive clutch material and a softer pressure plate.
BrokenRex is offline   Reply With Quote
Acura integra 94/2000 Clutch master/slave /pedal/set RSS-Bot Auctions 0 04-20-2008 10:43 AM
Honda Clutch Slave Cylinder B18C B16A JDM Civic Integra RSS-Bot Auctions 0 02-11-2008 02:53 PM
chaning the slave cylinder crxhero Prelude 2 11-28-2007 12:35 AM
WTB clutch master and slave cylinder, clutch lines Ignorant import guy Parts: For Sale/Trade/Wanted 5 03-28-2006 05:25 PM
slave cylinder rtpassini HYBRID -> EG-EK / DC 1 05-02-2004 02:01 AM
