what up. Ive been searching the net and asking people but nobody has been able to answer my question. I wouldnt mind building a crazy NA motor but the problem i face is compression vs octane. I no if someone wants to build a NA motor u need high compression, but the problem is that the higher compression u go, the higher octane u need to go. My problem is that in my area the highest octane u can buy at a pump is 94...i can buy octane boosters, but i dont want to buy a booster everytime i go to the pump. Does anyone no whats the highest compression u can have inside your engine using 94 octane before the gas spontaneously explodes because of compression
instead of spark. Thanx__________________
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the universe" - Albert Einstein |
B happy
Ride: dohc 95 egg
I mean there is a article about detonation that will give you a good idea about the compession question you have in regards to octane levels.
#5 |
where is the article? if it is the one in articles - detonation it only talks about psi...i need to no the compression of the pistons i need to buy so that it will work with the gas i can supply ( 94 octane )
#6 |
i think calesta is running 12.5:1 on 93 octane, that is probably the highest i'd go on pump gas
2005 Mitsubishi Lancer Evolution 8 2004 BMW 325i 2000 Mercedes Benz ML 430 1994 Honda Civic Del Sol VTEC (race kaa) |
#7 |
ya 12.5:1 is pretty high too...and i no i can get 94 so i dunno i try messaging him and asking him...thanx for the post b16
#8 |
B happy
Ride: dohc 95 egg
Sorry never said it would give you the exact figures your looking for,just a good idea of the theory and from there the world is yours.
#10 | |
Admin with a big stick
Ride: 2003 S2000
![]() __________________
#11 |
Don't forget, if you're ever out of your comfort zone where 94 octane is NOT available, you will have to be able to run the highest octane rating available with a bottle of octane booster (usually .6-.8 octane) and not get detonation..just something to think about.
#13 |
David
13.0:1 on 100 octane should work, but might nock and ping from predetination but won't harm the motor. for the 94 octane question yes, 11.0:1 will work even for highway use. That's coming from a honda/gm technician. |
#14 |
RETIRED
and you could always retard the dist. if you had to to get by on a tank of weaker gas, and NOT BEAT ON IT or take it up so high...
| Quick compression question | ratbastard | General Tech and Maintenance | 9 | 03-17-2006 04:59 PM |
| D16Y8 compression question | sula | Engine Building | 2 | 03-14-2006 11:34 AM |
| compression question | mustbenu | Engine Building | 1 | 01-23-2004 10:58 PM |
| Static vs. Effective Compression | pissedoffsol | Turbo Information | 0 | 01-12-2004 01:43 AM |
