I am building a lsvtec / stock b16 head with 11.5 c/r and i was wondering if there are any timing adjustment
( or any adjusments) to be made before i drive it ? will the stock b16 ecu work with the set up? thanks guys
b!+@# please. |
GNU/Linux Evangelist
Ride: The Cheapest Road Bicycle I could get
Which B16 ECU? I assume you are putting this engine into a 96 Civic Hatch (you name) if not which chassis is it going into?
I ran 11.5:1 on stock ignition timing no problems.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com |
I am not sure if you need to add fuel pressure with the B16 ECU, but I bet not. If anyone knows different, please correct me.
I know the stock ignition timing works with an OBD1 P72 ECU/Distributor. As for stock ignition parts, they will work great.
| Timing belt / timing gear problems | swapdohc | General Tech and Maintenance | 1 | 05-25-2004 11:43 AM |
| 12:1 compression TUNING | khai_tuan_nguyen | General Tech and Maintenance | 25 | 02-10-2004 01:45 PM |
| how to time | minivan | HYBRID -> ED-EF / DA | 2 | 02-03-2004 02:33 PM |
| Static vs. Effective Compression | pissedoffsol | Turbo Information | 0 | 01-12-2004 01:43 AM |
