Cost To Build A Ls/vtec
Closed Thread
Old 05-18-2003, 06:55 PM   #1
Rep Power: 14 dragoon118 is off the scale
Hi,
just wanted to know what the average cost for building a ls/vtec motor would be. Is 4000 about rite for a decient built ls/vtec?
Ac
92 si black like the night stalker w/ fully built b18c.
and it looks totally stock....ha ha ha
dragoon118 is offline
Old 05-18-2003, 07:24 PM   #2
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
It really depends. What parts do you already have? What car is getting the engine?
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline
Old 05-23-2003, 07:45 AM   #3
Rep Power: 15 THiroshima83 is off the scale
well lets see... ls block goes for like 400... ctr pistons 300....b16 head 450... and you might want to port and polish it(900). then some ctr camshafts 500....tranny... clutch all that.. hmmm that sounds about right.. to me
THiroshima83 is offline
Old 05-23-2003, 08:21 AM   #4
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
a 900 dollar port and polish?? damn!!!
pills_PMD is offline
Old 05-24-2003, 04:10 AM   #5
i got a guy who said like 5 grand. but its fully built blue printed and balance bottom end and race pot and polised head. with type r manifold, ctr pistons, and type r tanny with lsd. he said mostly type r parts would be installed ie water and oil pump small stuff like that. is that a good deal? what else should i bee looking to get?
Old 05-24-2003, 07:56 PM   #6
wow.. 5000 for all OEM parts? for 5 g's expect to get aftermarket rods and pistons at least.
balancing only costs about 200-300 if you know the right people
too much
Old 05-24-2003, 08:32 PM   #7
hi,
what should i be looking to pay for the set up i listed above?
ac
Old 05-25-2003, 12:01 AM   #8
lsvtec's Avatar
Hell my balance job cost me $120, I brought him my stuff and he said he didn't have to touch anything on the pistons or rods as they were well balanced to begin with and he had to remove a little of my crank.
lsvtec is offline
Old 05-25-2003, 02:10 AM   #9
Rep Power: 14 JDMPowersales is off the scale
Importreview.com did a great article on this. I think its about 5000 in parts and labor with out the LS motor. If you want it done right remember cheap things end up haunting you 1/2 the times.
<span style=\'color:green\'><span style=\'font-family:Optima\'>OBD1 and OBD2 ZC motors 700.00 USD
F20B 2850.00
F22B 500.00
ZC 550 OBD0 , OBD1&amp;2 700.00
B16a Hydro 2199.95 Auto 1550.00
B16a Cable 1299.95 Auto 999.95
H22a Auto 1550 Manual 2099.95 shipping 250-350
</span></span> Dont use the &quot;my wife cant drive stick excuse on me&quot; I understand :P
JDMPowersales is offline
Old 05-25-2003, 03:25 AM   #10
Rep Power: 20 AllMotorMonster is an unknown quantity at this point
All prices are about average, not as hearsay.
LS block = 400
B16A head = 550**
Hydro tranny = 650 *GSR/SIR
Clutch = 300
Linkage = 100
Axles = 250
Engine harness = 150 *depends on OBD1 or OBD2 costs may be higher
ECU = 250 *stock GSR or programmed P28
Pistons B16A = 25/ea *cannot use with aftermarket rods.
Rings 81mm = 20/ea
ARP rod bolts = 45 *for the LS rods if you are planing on using them.
Pistons aftermarket = 425/set *comes with rings, can use on stock rods if machined.
Rods = 350 *Eagles. They are the least expensive good rods, the factory LS rods will NOT handle revs over 8000 stock, and not over 9000 with ARP rod bolts. Don't cheap out here, these are the heart of your engine. Failure here can result in all your money lost.
Rod bearings = 64
Head gasket = 55
Other misc gaskets for install = 100 (oil pan, camshaft, intake manifold, exhaust manifold, water pump, oil pump, etc, etc...)
**Assuming the head came with intake manifold, dizzy, injectors, t-body, etc, etc.....
I busted out some reciepts for machine work and labor costs from my stroked/bored GSR engine.
Press pistons on - 60
Bore block, torque plate - 120
Balance crank, pistons, rods - 200
Shotpeen rods - 80
Port and polish head, intake manifold, exhaust manifold. All gasket matched - 950
Clean and tank head and block - 100
Now, I did all the assembly myself, so I saved major $$$$ over having someone else do it for me.
So add it all up, then figure about 20% more just in case. You never know what you may run into when doing something like this.
<a href=\'http://www.ask.com\' target=\'_blank\'>Learn everything you ever wanted to know about engine building, chassis setup and ECU's</a>
AllMotorMonster is offline
Old 05-26-2003, 11:26 AM   #11
whoa gsr tranny for 650! im a vendor and I cant even roll them up they are more like 750-1000. Most head will not come with intake manifold too. OEM B16a pistons are about 50 each. I dont quite remember. I had to buy some and it came out to 180-200.00. I could of gotten CTR alot cheaper but was in desperate need.
F20B 2850.00
F22B 500.00
Old 05-26-2003, 06:45 PM   #12
i got .25mm over pr3 pistons with rings for 100 bucks
Old 05-26-2003, 09:30 PM   #13
Tre
Rep Power: 14 Tre is off the scale
new or used and where?!
Tre is offline
Old 05-26-2003, 11:13 PM   #14
Rep Power: 14 liquid8 is off the scale
are new pistons a must???
liquid8 is offline
Old 05-26-2003, 11:55 PM   #15
lsvtec's Avatar
I have seen cars run fine on LS pistons, you have to be careful with your cam gears and the cams you run. It just doesn't make any sense not to replace them. You have the engine apart already you migh as well go for more compression.
lsvtec is offline
Old 05-27-2003, 01:27 AM   #16
brand new from "happycorepuppy" on hondavision. but i think it was an only set ..
Old 05-27-2003, 02:19 AM   #17
is it true that the b18 and b16 have the same bore but just different stroke. giving it more displacement
liquid8 is offline
Old 05-27-2003, 02:25 AM   #18
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 546 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
yes
МОΛΏΝ ΛΑΒΈ
E_SolSi is offline
Old 05-30-2003, 08:34 PM   #19
Tre
heres a list of te costs of how much machine work ill cost me for my ls/vtec
(PRices are in cdn)
Shotpeen rods $60
Resize rods for arp bolts $75 ($10 for installation and $45 for the bolts)
Hone block $50
Clean block, crank, rods $90
Rod/Piston alignment/press pin in $55
Polish Crank $50
balance bottom end (flywheel, crank, rods, pistons) $195
flywheel lighten $90
flywheel resurface $50
knife-edge crank - $180
The guy also says new HONDA rod/main bearings would cost $300+ !!
arp head studs $80-100
Tre is offline
Old 02-09-2009, 02:07 AM   #20
Greenhorn
Rep Power: 0 Myhondasleepsforno1 is on a distinguished road
Thumbs up Do it right or not at all
B18 block
gsr girdle
spoon oil pump
type r water pump (or gsr)
Crower crank
Eagle rods
12:6:1 Je srp pistons
bored 81.5 with eagle sleeves
golden eagle ls vtec kit
b16 head port polished milled and hot tanked
super tech valve springs
titanium retainers
(can do bronze valve guides but they wear out faster)
buddy club spec IV cams
skunk 2 pro series cam gears
Toda timing belt (kevlar)
Skunk 2 intake manifold
skunk 2 fuel rail
310 RC injectors
sard fuel pressure regulator
walbro fuel pump
blox throttle body with tps (throttle positioning system)
password jdm intake carbon fiber
b16 tranny
short shifter
act lightened flywheel
act street racing clutch
arp flywheel bolts
iridium NGK spark plugs
vision spark plug wires
skunk 2 cam seal
type R red valve cover
carbon fiber spark plug cover
p28 ecu
skunk 2 oil cap
password JDM magnetic oil and tranny plug
buddy club header and test pipe
RSR exhaust
tein coilovers springs and shocks
skunk 2 front and rear camber kits
sustec front and rear strut bars
( i only need front and rear skunk2 lower control arms)( and I might get traction bars)
(and if you really want to be crazy go itbs (individual throttle bodies))
Anyway this is my ls vtec build and it was expensive to say the least but done right damn right let me know what you think.
Myhondasleepsforno1 is offline
Old 02-09-2009, 04:52 PM   #21
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
Originally Posted by Myhondasleepsforno1 View Post
B18 block
gsr girdle
spoon oil pump
Crower crank
Eagle rods
titanium retainers
skunk 2 fuel rail
310 RC injectors
walbro fuel pump
b16 tranny
short shifter
arp flywheel bolts
skunk 2 cam seal
p28 ecu
skunk 2 oil cap
RSR exhaust
Sounds like a nice build, but the thread was almost six years old bro..lol
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline
Old 02-09-2009, 07:30 PM   #22
D-Series Ninja
riceracerex's Avatar
Ride:  90' Honda CRX Si
Rep Power: 11 riceracerex is a jewel in the roughriceracerex is a jewel in the roughriceracerex is a jewel in the roughriceracerex is a jewel in the rough
myspace
I guess it's making a comeback! What about the cost of a stock B18B swap. Full motor, no mods, just the swap. Does it need different mounts and such. Add it up.
"¿ʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı" uɐɯ ǝlqısıʌuı uɐ ɟo sɹıoɯǝɯ ɯoɹɟ ǝʇonb ɐ ɟo pǝpuıɯǝɹ ɯ,ı
riceracerex is offline
Old 02-09-2009, 10:02 PM   #23
austin20110's Avatar
Ride:  96 civic coupe, 05 s2k project car with buddies
Rep Power: 39 austin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud of
Send a message via AIM to austin20110
That was a nice copy and paste
Originally Posted by packardbell View Post
i plan to modify it to the max and swap out the motor and go fi.
austin20110 is offline
Old 10-13-2009, 05:38 AM   #24
Greenhorn
Ride:  97 integra B18C
Rep Power: 0 B18Ctec is on a distinguished road
Hi I have a 97 integra B18C what would make my car faster better pistons or get some cams???
B18Ctec is offline
Old 10-13-2009, 07:43 PM   #25
F.I. Junkie
B18Ctec, start your own thread and check the dates on topics before posting please. Locked.
-320 WHP EJ6-
Closed Thread
LS/VTEC build need help IntegralTendencies Engine Building 2 06-25-2004 05:20 PM
Ls/vtec build KWJaY Engine Building 10 08-31-2003 06:13 PM
I Need Prices For Good Ls/vtec Build TYPE-R-RACER Engine Building 1 06-17-2003 11:42 AM
Ls/vtec Build Mech HYBRID -> ED-EF / DA 18 06-12-2003 12:17 PM
Build An Ls/vtec 1st Or Turbo It? acurabdby Forced Induction 10 05-15-2003 07:53 PM
