Crank gridle or not
Closed Thread
Old 10-22-2002, 02:22 PM   #1
b20vtecbuilder is off the scale
Unhappy
I was wondering if i should put a crank gridle in my b20b block. I'm using a stock sir-2 head for now so i don't plan on revin' past 8500 rpm's. And even if i use the z10 gridle do i still need to do machine work for it to fit properly. thanks for your help
b20vtecbuilder is offline
Old 10-23-2002, 12:03 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
yes yes yes. this is a key part to a frankenstien build!!!!
pissedoffsol is offline
Old 10-23-2002, 10:31 AM   #3
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Calesta has a reputation beyond repute
Calesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond repute
No you don't need it- take it from someone who actually runs this setup. I rev to 8000 all day, and 8500 holds just fine too. 40k miles and still running as strong as day one...
The girdle is good insurance though. I don't have one in mine, but I'm getting one. So no- you don't need it, but it's nice to have 'just in case'. I'm not sure if you need to machine the block to get the Z10 girdle to fit, but I don't think you have to. That's what I've been told, anyway. The GSR girdle can be used also, but I think that it does require some machine shop time.
Calesta is offline
Old 10-23-2002, 10:38 AM   #4
hey thanks for the info. if you dont mind me askin what block setup are u running. (pistons, c.r., ect)
Old 10-23-2002, 11:10 AM   #5
Calesta's Avatar
Ride:  2003 S2000
Hit the link in my sig. Note that the compression is really 12.6:1, not 12.5:1 as stated on my page. I recalculated the compression with all the right values, and 12.6:1 is the actual number.
Calesta is offline
Old 10-23-2002, 11:47 AM   #6
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
lsvtec is on a distinguished road
The Z10 website claimed that you did not need any machine work on an LS bottom end to install the girdle. Which is why they push it over the GSR girdle. If you have the money for the girdle without chaning the other things you are getting for the motor then get it. But if you have to choose between something like rods or the girdle, take the rods and get the girdle later.
lsvtec is offline
Old 10-23-2002, 11:55 AM   #7
lsvtec's Avatar
Check out http://www.z10eng.com/products.cfm#bg for more info but they claim that you do not need machine work done to any B series motor to accept the girdle, you do however need
GS-R / Type R Main Bolts, Windage Tray, Oil pump pickup, Oil Tray all contained within Part #Z10-2020
Unfortunately this product will not work in my Integra because the GSR oil pan sits right on the header causing the oil to boil. Dammit.
lsvtec is offline
Old 10-23-2002, 12:36 PM   #8
Member of the 20 nut club
E_SolSi's Avatar
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
lsvtec ... you might wanna take a look at this
http://www.inlinefour.com/spoonheatbar1.html
E_SolSi is offline
Old 10-23-2002, 12:50 PM   #9
lsvtec's Avatar
The issue is the oil pan actually comes in contact with the exhaust manifold if I use a B18C oil pan. I dont' think that this product would prevent heat transfer through conduction very well. I have never tried a B17 oil pan. I wounder if that would work with the girdle.
lsvtec is offline
Old 10-23-2002, 02:26 PM   #10
Calesta's Avatar
Ride:  2003 S2000
Hmmm. Phillip's using a Z10 girdle on his B20/VTEC with the GSR oil pan and a DC 4-1, and he doesn't have any contact issues that I know of.
Calesta is offline
Old 10-23-2002, 02:43 PM   #11
so which header would i need for it to clear the oil pan properly if i where to use the gsr oil pan
Old 10-23-2002, 02:52 PM   #12
Calesta's Avatar
Ride:  2003 S2000
Ask me once I get the girdle put on.
Calesta is offline
Old 10-23-2002, 03:07 PM   #13
do u have any problems runnig that compression on pump gas (91 octane) cuz i can't decide which pistons i want to use. i have i narrowed down to endyn and je but je only makes 10.5 and 12.5:1 comps. but endyn are much heaver then je pistons. Any suggestions?
Old 10-23-2002, 03:58 PM   #14
Calesta's Avatar
Ride:  2003 S2000
You can run the 'race only' strutted skirt Endyn pistons on the street if you really feel like it- Intercrew's got an engine set up this way and it drives great off the track.
I have problems with 91 octane- it detonates all the time. Texas sells mostly just 87, 89, and 93, so my 12.6:1 compression isn't a problem. 93 octane holds it down just fine, but 91 is too low. If you're looking at running on 91, you might consider using a thicker head gasket or having a custom set of pistons made. You could probably get away with 12.0:1 or a high 11.x:1 compression ratio on 91 octane gas.
Calesta is offline
Old 10-24-2002, 12:27 PM   #15
lsvtec's Avatar
I don't think any other chassis has the clearance issues. Only the DA.
lsvtec is offline
Old 05-16-2003, 02:57 PM   #16
JDMilan is off the scale
Use the Z10 girdle so that you can sleep at night better,,,,,,,,
Yeah, you could do the 2.0vtec without, just cause you can do it doesn't mean it's to be done.
Milan
JDMilan is offline
Old 05-16-2003, 08:13 PM   #17
Calesta's Avatar
Ride:  2003 S2000
Wow.... hopefully he's already made the decision and either added the girdle or not after 7 months.
Resurrecting dead threads sucks.
By the way, I had no problems without a girdle for 45k miles on my B20/VTEC, and what killed it eventually wasn't anything to do with the bottom end coming apart.
Calesta is offline
Closed Thread
Crank hard to turn by hand? Normal? hmtcrxsir Engine Building 13 11-02-2005 12:13 PM
Crank perforance UDT General Tech and Maintenance 3 03-04-2004 05:28 PM
LS crank in GSR block? totalimpact Engine Building 4 09-02-2003 10:15 PM
Crank Swap Teamsprock Engine Building 3 07-31-2003 01:08 PM
CTR, ITR, or stock B16a crank pulley? sol2nr Engine Building 10 07-11-2003 05:32 AM
