ctr piston clearance
Old 12-22-2002, 09:12 PM   #1
Rep Power: 0 vwhondahatches is off the scale
Thumbs up
plastiguaging cams and pistons? um no, think you got that confused with claying the motor for piston to valve clearance. I have 2 friends with CTR pistons. One runs Skunk Stage 1's. and The other runs TODA Spec B's. But with any motor you want to clay it. And if on a VTEC motor you want to make sure your running off your vtec lobe because thats where your biggest lift and duration numbers are.
vwhondahatches is offline   Reply With Quote
Old 12-22-2002, 11:01 PM   #2
Rep Power: 20 Canuck 93 Civic Si is off the scale
Send a message via ICQ to Canuck 93 Civic Si
Good site http://www.c-speedracing.com/howto/claymotor/clay.php
Are you sure it was something you read in a book. Are you sure it wasnt..... Nothing?
Canuck 93 Civic Si is offline   Reply With Quote
Old 12-24-2002, 09:03 AM   #3
Rep Power: 17 chris is off the scale
Send a message via AIM to chris
oops, ya i meant claying to check valve to piston clearance not plasicguage for checking rod and main bearings.
Used performance parts straight from Japan/road race questions: <a href=\'http://www.rcrewracing.com\' target=\'_blank\'>www.rcrewracing.c om</a>
chris is offline   Reply With Quote
piston to valve clearance specs and some other help needed GSRCRXsi Engine Building 11 05-21-2006 09:00 PM
piston to valve clearance question BigBoy Engine Building 1 10-27-2005 02:48 AM
piston clearance and CR 22crazy Engine Building 1 03-02-2004 12:44 PM
How to Compute the Compression Ratio of a motor pissedoffsol General Tech Articles 0 01-12-2004 01:41 AM
Piston To Valve Clearance rookiehondafreak Engine Building 1 05-19-2003 08:19 PM
