CTR pistons streetable in LS?
Old 10-02-2003, 02:26 PM   #1
88 C1V1C 53D4N DR1V3R
saturn_boy96's Avatar
Ride:  2006 Suzuki Aerio
Rep Power: 31 saturn_boy96 will become famous soon enough
Send a message via AIM to saturn_boy96 Send a message via MSN to saturn_boy96 myspace
Are CTR pistons streetable in a basically stock LS? just wondering cause those are cheaper than new stock pistons and they are cheaper than US or JDM b16a pistons.
saturn_boy96 is offline   Reply With Quote
Old 10-02-2003, 02:43 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Should be.
Old 10-02-2003, 02:45 PM   #3
B16
B16's Avatar
yes, you can be streetable, don't know about smog laws where you are from though, but you will be running around 12:1 CR
2004 BMW 325i
2000 Mercedes Benz ML 430
Old 10-02-2003, 03:28 PM   #4
Rep Power: 27 SleEPeR_CRX is off the scale
yes u can use them, but u should use b16 rods to.
Sleepers Are the Only way to Go.
1990 CRX Si
B18a(92) CAI/E, Gutted, ACT clutch/pressure plate/13lb flywheel, Crower 403 Cams, Titanium Valve springs & Retainers, Blockguard, Head Milled 20 thou, 9.8:1 Compression, AEM cam gears.
1/4 = 14.73
60' = 2.48
trap = 95.03mph
Soon to get: Header, Slicks
Future 13 second all motor LS!
SleEPeR_CRX is offline   Reply With Quote
Old 10-02-2003, 04:27 PM   #5
Calesta's Avatar
Ride:  2003 S2000
Why would you want to do that? You would lose more than 200cc of displacement...
Old 10-02-2003, 07:36 PM   #6
B16
B16's Avatar
Originally posted by Calesta+Oct 2 2003, 12:27 PM--><div class='quotetop'>QUOTE(Calesta @ Oct 2 2003, 12:27 PM)</div><div class='quotemain'> <!--QuoteBegin-SleEPeR_CRX@Oct 2 2003, 02:28 PM
Why would you want to do that? You would lose more than 200cc of displacement... [/b][/quote]
you wouldn't loose displacement, since the crank doesn't change size, but your compression ratio would drop a whole lot
2004 BMW 325i
Old 10-02-2003, 07:50 PM   #7
Calesta's Avatar
Ride:  2003 S2000
Originally posted by B16+Oct 2 2003, 06:36 PM--><div class='quotetop'>QUOTE(B16 @ Oct 2 2003, 06:36 PM)</div><div class='quotemain'>
you wouldn't loose displacement, since the crank doesn't change size, but your compression ratio would drop a whole lot [/b][/quote]
Me = idiot, read wrong. That would be a HUGE compression drop though- totally defeating the purpose of using the CTR pistons.
Old 10-03-2003, 12:23 PM   #8
i live in wyojming so basically no smog laws. but the best i can get here is 91 octane.
i'm trying to decide which would be better, jdm p30 pistons or CTR's.
Old 10-04-2003, 12:35 PM   #9
Calesta's Avatar
Ride:  2003 S2000
Well, it looks like JDM P30 pistons will give you 11.3:1 compression, while the CTR pistons will run you up to 11.7:1. Both are streetable on 91 octane if you tune the engine well. Consider that Honda ships the S2000 with 11.0:1 compression and Toyota ships the Celica GT-S with 11.5:1 compression, and both have to run on 91 octane with a conservative tune.
Old 10-05-2003, 10:24 PM   #10
what kind of tuning stuff should i look into? would an SAFC be overkill?
Old 10-06-2003, 04:27 PM   #11
anyone know?
Old 10-08-2003, 08:20 AM   #12
Calesta's Avatar
Ride:  2003 S2000
SAFC or Hondata would be fine.
b16 pistons - PR3 Anthrax-VX Parts: For Sale/Trade/Wanted 1 05-11-2004 06:21 PM
Need pistons for buildup Teambypass Engine Building 24 03-11-2004 12:39 PM
are 12 cr pistons streetable? word Engine Building 16 02-04-2004 03:28 PM
