Facebook Twitter
Custom Crank Pulley
This is a discussion on Custom Crank Pulley in the Engine Building forum
I need to know a way of eliminating the outer 2 grooves on my crank pulley. One is for P/S which I'm not using, The other is for A/C (also not using). I only need the groove for the alternator belt (which is the one ...
Old 10-11-2006, 01:06 PM   #1
Default Custom Crank Pulley
I need to know a way of eliminating the outer 2 grooves on my crank pulley. One is for P/S which I'm not using, The other is for A/C (also not using). I only need the groove for the alternator belt (which is the one closest to the crank). If anyone knows where I can buy a pulley like this, I'd appreciate it, cuz the guy at the machine shop said he can't cut the pulley down. It's for the 89 Acura D16A1. I need that extra couple inches for clearance when i swap it into the civic. Thanks for any help.
Go to work, Act normal, Believe the News, Save for your old age, Obey the Law
Repeat after Me: I am Free
klyph is offline   Reply With Quote
Old 10-11-2006, 01:14 PM   #2
I would think that the pulley would be the same as any other D-series...look on Ebay, they have 'unorthodox' pulleys on there all the time...
civicious is offline   Reply With Quote
Old 10-11-2006, 01:27 PM   #3
Thanks, but all the unorthodox pulleys I have found are set up just like stock, for 3 belts. I need to find a pulley with just 1. Anyone know how i can do this?
Old 10-11-2006, 02:01 PM   #5
Domo! I am forever your humble servant.
Old 10-16-2006, 07:50 AM   #6
i can make you a stock one and ship it out to you if you dont want a underdrive pully i have a lathe and have turned down many of these for people.
97hatch is offline   Reply With Quote
Old 10-17-2006, 10:53 PM   #7
Yurik's Avatar
i actually bought a JDM factory honda part that illiminates those belts from a guy on ebay, came with the factory part # and everything, pretty sweet piece to say the least, that is also for a b16, but i would check ebay for sure
Yurik is offline   Reply With Quote
Old 10-18-2006, 08:25 PM   #8
K2e2vin's Avatar
Thats the CTR N1 pulley; will only fit B-series.
Old 10-27-2006, 12:21 AM   #9
CrazyAzn's Avatar
ctr pulley ftw
CrazyAzn is offline   Reply With Quote
Old 10-28-2006, 05:03 AM   #10
MikeBergy's Avatar
There was a guy on the m24x forums that did this service as well, ths 'soyboy' or something like that. It retains the stock damping material, so I'd recommend do ing this over aftermarket. Just make sure and get it balanced.
MikeBergy is offline   Reply With Quote
Old 10-28-2006, 02:38 PM   #11
Yeah, i got the unorthodox pulley. Mmmm shiny. Anyways since I now gotta spin balance the engine I'm puttin a lighter flywheel on. I was gonna go with a Fidanza Aluminum 7 lb. Anyone have any thoughts on these flywheels or recommendations as to what flywheel i should get.
Crank Pulley HELP HatchSpeeD General Tech and Maintenance 30 09-25-2007 08:54 PM
UR Crank Pulley m2slsvtec671 Engine Building 6 06-24-2004 01:14 AM
H22 Crank Pulley Swap reckedracing Engine Building 3 01-25-2004 02:29 PM
replacing a crank pulley civicious Engine Building 7 07-25-2003 06:20 PM
CTR, ITR, or stock B16a crank pulley? sol2nr Engine Building 10 07-11-2003 05:32 AM
© 2001-2013 HondaSwap.com
