Facebook Twitter
d15b2 rods
This is a discussion on d15b2 rods in the Engine Building forum
I'm doing an engine build and wanted to try something different and build the d15. does anyone know where I can find forged rods? I can find the pistons but not the rods. I can find d16 ones, but those are .2" longer, how much ...
Old 07-07-2009, 02:35 PM   #1
Default d15b2 rods
I'm doing an engine build and wanted to try something different and build the d15. does anyone know where I can find forged rods? I can find the pistons but not the rods. I can find d16 ones, but those are .2" longer, how much of a difference would that make? If anyone knows where I could get the right ones I would really appreciate it.
Bobby17772 is offline   Reply With Quote
Old 07-07-2009, 04:17 PM   #2
jlicrx's Avatar
D16 rods won't work - the rod journals on the D16 cranks are 45mm and on the D15 cranks, they are 42mm - for building a D15, you are better off starting out with the JDM D15B VTEC engine which uses the larger crankshaft 55mm main (D15 is 45mm) and 45mm rod journals like a D16 - also uses D16 rods with pistons that have a shorter compression height
there are D15 rods available, but they are a lot of money:
CROWER B93741 CONNECTING RODS SET: CIVIC 92-95 (D15)
Pauter Rods: No Limit Motorsport
Old 07-08-2009, 11:30 AM   #3
yeah thats what I herd, just get the jdm d15 crank, use d16 rods and pistons, and of course bore the block to fit of course. thank you for the help.
Oh and lastly, is a d series the same no matter what generation it goes to? Because I've been seeing things like for the 92-95 models, so I just wanted to make sure before I order things
Eagle Rods Civic D16 Turbo connecting rods BRAND NEW!!! RSS-Bot Auctions 0 02-19-2009 11:03 AM
OH WTB D15b2 or B20 EthanC Parts: For Sale/Trade/Wanted 7 09-05-2008 07:59 PM
d15b2 89EF HYBRID -> ED-EF / DA 2 04-22-2007 10:47 PM
D16a1(dohc) pistons on d15b2 rods??? theB16tegguy Engine Building 1 11-19-2003 10:53 PM
sohc rods? jdm vtec d15 & d16z6 rods the same?? Slammd Sol HYBRID -> EG-EK / DC 3 11-18-2003 02:03 PM
© 2001-2013 HondaSwap.com
