D16Y7 Block W/ D16Y8 head
Old 10-02-2004, 09:27 PM   #1
Rep Power: 0 98ejsir2 is off the scale
Im asking this for a friend. He wanted to know if you could put a D16Y8 head on a D16Y7 block without having to tap the block for vtec? Also he wanted to know what kind of problems he was goin to run into put the motor in a 89 h/b?
98ejsir2 is offline   Reply With Quote
Old 10-04-2004, 12:44 AM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
You only have to tap B series blocks on VTEC head conversions. Just make sure there's no oil jet left in the block between cylinders 2 and 3, then bolt everything up and it's all wiring from there on out.
Putting that engine combination into an 89 HB should be the same as installing a D16Y8.
By the way, wrong forum.
