d16y7 with y8 head
Old 10-25-2009, 02:53 PM   #1
Greenhorn
Ride:  Civic CX-G 1997
Rep Power: 0 Shook one is on a distinguished road
Question d16y7 with y8 head
i just got my new 97 cx-g hatchback civic with 83k miles on it. I will probably do a mini me swap with a rebuilt y8 head. i got a complete tutorial from jdmuniverse.com (***D16 Mini Me Swap Write Up*** - JDM Universe.com) and the guy says that he used the d16y8 fuel rail, so i was wondering if i could use my d16y7 fuel rail instead of buyin a new y8 fuel rail. he also said that he used a p28 ecu because it is obd 1 and its easier to program. but can i use a p2p instead because i dont want to make the odb1 conversion. also, i will probably change my cam shaft but i don't really know which one i should buy(from which company, what stage i should use, etc). i would like to know also i the vtec distributor is the same thing than the vtec solenoid ?
Thanks in advance !
Shook one is offline   Reply With Quote
Old 10-25-2009, 03:19 PM   #2
tabKola's Avatar
Ride:  civic ek 4 door
Rep Power: 5 tabKola is on a distinguished road
-You can use the P2P ECU as long as it is OBD2A and for a 5 speed if your car is a 5 speed or auto if you are auto.
-Distributor and VTEC solenoid are different things ,but if you get an OBD2A P2P ECU you can just use the Y7 distributor with it.
-I don't know if the fuel rails are different, but I know you definitely need Y8 injectors.
tabKola is offline   Reply With Quote
Old 10-25-2009, 09:01 PM   #3
Greenhorn
ok thanks, but I would also need some information about camshafts.. I don't really know what is the difference between stage 1 stage 2 and 3.. i know it as something to do with rpms but i don't really know.. thanks
Old 10-27-2009, 09:39 PM   #4
Greenhorn
someone ??
D16Y7 to Y8 Head Swap.... What I Need biglonglenthman Engine Building 11 04-10-2008 03:43 PM
97 civic d16y7 head RSS-Bot Auctions 0 03-29-2008 02:13 PM
LF d16y7 non vtec head combz Parts: For Sale/Trade/Wanted 1 11-14-2007 12:24 AM
D16y7 block with d16z6 head in a 95 del sol. Which head bolts and which ecu? joshisakson_ Engine Building 0 03-27-2007 11:10 PM
CAN I FIT A 91 SI D16A6 HEAD ON A 97 D16Y7 4BANGERD16Y7 HYBRID -> EG-EK / DC 3 07-12-2003 05:07 AM
