D16Y8 NA Build up Advice Needed
Old 08-04-2009, 09:41 PM   #1
Rep Power: 2 wildcat820 is on a distinguished road
Default D16Y8 NA Build up Advice Needed
Heres the scoupe, I Dirt race a CRX with a D16Y8 from an EX civic in it. I am looking to build up a True race motor for end of season/next year. Before you spout off about Dual cam or B series RUELS STATE SOHC ONLY/Vtec OK
I have the car set up running obd o Computer and I activate the Vtech with Shift light. It was my most simple setup. and it works flawless! plus I can vary the vetch for extreamly black slick or Slimey conditions. I am using B series compter 7200 revlimiter but also have a 10000 rpm computer (GSR I Belive) I can run on the built motor.
So whats you opinions on a build up? What cam? everything I look for is Turboed, Has to remain NA Best brand of pistions and rods? Oil pump? any high RPM tips like drilling any Oil galleys or a builder out there I should consult?
wildcat820 is offline   Reply With Quote
Old 08-04-2009, 09:49 PM   #2
By the way, Its got a header, and a R throttle body already. How much compresion can i push? It is currently run on E85 with the fuel pressure Up and a Walboro Pump
Old 08-10-2009, 08:39 AM   #3
Nobody??? how much compression can I run? Anyone???? Come on guys? rods? crank? good parts sorce or Builder?
Old 10-27-2009, 02:25 PM   #4
D-Series Ninja
riceracerex's Avatar
Ride:  90' Honda CRX Si
Rep Power: 11 riceracerex is a jewel in the roughriceracerex is a jewel in the roughriceracerex is a jewel in the roughriceracerex is a jewel in the rough
myspace
The highest I have seen is 13:1 on a single cam but it's a little too risky to run that high. Look into a block guard and I would not recommend trying to hit 10k Rpms.
riceracerex is offline   Reply With Quote
Advice needed mystikal-vti HYBRID -> ED-EF / DA 1 01-29-2009 11:25 AM
Advice needed. philyphreak2127 HYBRID -> EG-EK / DC 6 12-12-2007 06:54 PM
D16Y8 Advice Needed johnson_racing Civic and del Sol - EG and EK 7 05-02-2007 05:43 PM
advice needed on ecu white lude HYBRID -> BA-BB /CA-CD 3 10-30-2004 01:06 PM
advice needed Vtec=V8 killa HYBRID -> ED-EF / DA 0 03-01-2004 10:47 PM
