does anybody know where the Baro sensor is?
Old 02-01-2004, 12:27 AM   #1
CRXproject is off the scale
Send a message via AIM to CRXproject
i have an 89 honda crx si 1.6, its giving me a code of 13 flashes wich indicates that the Barometric Pressure Sensor might be un hooked, or damaged. does anybody know where it is so i can check it?
CRXproject is offline   Reply With Quote
Old 02-04-2004, 06:56 PM   #2
Russ is off the scale
I guess not.
Russ <><
Russ is offline   Reply With Quote
Old 02-04-2004, 07:39 PM   #3
TWAN will become famous soon enoughTWAN will become famous soon enough
Passenger side kick panel, right below the dash
TWAN is offline   Reply With Quote
Old 02-04-2004, 08:34 PM   #4
red95solsi is off the scale
Send a message via AIM to red95solsi
baro is inside the Ecu... sounds like you need a new ecu
red95solsi is offline   Reply With Quote
Old 02-04-2004, 08:49 PM   #5
that is on 1992 and up, on the ef, the sensor is on the right kick panel. it is actually called the atmospheric pressure switch. If you want to argue with me fine, but i am looking at the honda shop manual right now. the part number is 37836-PH7-003
