Dyno chart for my new engine build
Old 09-18-2003, 02:30 AM   #26
Rep Power: 25 SixtySecondAssassin is off the scale
come pick me up. i forgot what a good running honda feels like.
.....deagle.....
SixtySecondAssassin is offline   Reply With Quote
Old 09-18-2003, 03:07 AM   #27
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Calling.
Old 09-18-2003, 03:15 AM   #28
Banned
Rep Power: 0 Tonyd0821 is off the scale
Send a message via AIM to Tonyd0821
out of curiosity Cal....
im guessing you are around....
mid to low 14's?
185whp on a hatch? (forgive me if it is a 4dr, didnt take the time to read)
Tonyd0821 is offline   Reply With Quote
Old 09-18-2003, 03:22 AM   #29
Rep Power: 30 SolReaver is off the scale
mid to low 14's?
i bet he is faster than that...mid 13's or so...he has a sedan
well done calesta...VERY impressive torque numbers...
did you get the pm i sent you?
<a href=\'http://www.FreeiPodShuffle.com/default.aspx?r=15723497\' target=\'_blank\'>Get a free ipod shuffle, Yes it works! </a>
I will paypal $8 to the first 3 people to complete the offer, PM me if interested.
SolReaver is offline   Reply With Quote
Old 09-18-2003, 03:25 AM   #30
im going for a ride beyotches!
.....deagle.....
Old 09-18-2003, 05:27 AM   #31
the civic has some fucking balls man!
.....deagle.....
Old 09-18-2003, 06:22 AM   #32
Calesta's Avatar
Ride:  2003 S2000
Tony- it's a sedan, and I'm betting it's closer to mid 13s. No quarter mile runs yet, and I don't know when I will be out at the strip next.
SolReaver- no, I didn't get a PM from you.
Sixty- fun ride, eh?
Old 09-18-2003, 10:25 AM   #33
Rep Power: 29 Frankie P. is off the scale
Send a message via Yahoo to Frankie P.
Yeah, it feels like a mid 13 car, seems about as fast as my friends 2001 Cobra, feels a little different, because I am used to twice as much torque, still a great car.
Frankie P. is offline   Reply With Quote
Old 09-18-2003, 01:50 PM   #34
Rep Power: 17 quicksi is off the scale
Send a message via AIM to quicksi
Now won't you have clearance issues with Toda C's if your running almost 12:1 comp? also, the Jun 3's and skunk 2 stage 2's make power almost all they way up to 9000 RPM if not higher.lllcan your bottom end with a 89 mm stroke safely handle those revs???
99 Honda Civic Si - Powered by 1.21 Jiggawatts of electricity
quicksi is offline   Reply With Quote
Old 09-18-2003, 03:02 PM   #35
Calesta's Avatar
Ride:  2003 S2000
Thanks Frankie.
quicksi- you NEED compression that high to take advantage of the Toda Spec Cs. I personally know a very good tuner that runs compression in the 15s with Toda Cs, and the valves clear. The Jun 3s and Skunk2 Stage2s make power all the way up to 9000rpm, but they don't have the midrange that the Toda Cs do. The Todas make the same high end power as the Juns and Skunks, so that's where I'm looking to go for a fuller power curve.
The bottom end will handle the revs just fine, even with the 89mm stroke. The overall stroke geometry is the exact same as the GSR and ITR, and I still have the advantages of oil squirters and a girdle.
Old 09-18-2003, 03:09 PM   #36
yeah, great job so far mang..keep it up..then when my SR is running and I actually come visit you peeps up north we can see how linear that powerband really is..
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 09-18-2003, 03:23 PM   #37
Calesta's Avatar
Ride:  2003 S2000
Thanks! "Up north?" Are you in Mexico or something? Texas is about as far south as you get in the US!
My car is done, engine build a success. Dyno here Import Builders Engine Building 23 06-25-2004 01:08 AM
How to build a panda engine Kolumbo69 Engine Building 6 01-04-2004 07:43 PM
Build Engine Or Swap? 98 4dr civic Engine Building 6 06-05-2003 10:33 PM
My Engine Swap Continues rsaeini HYBRID -> EG-EK / DC 23 03-22-2003 03:22 PM
D16 Engine Build pianoman Parts: For Sale/Trade/Wanted 1 03-17-2003 12:41 AM
