Which ECU for LS/Vtec?
Old 08-30-2003, 02:37 PM   #1
The Seniorest Member....
scottp11's Avatar
Ride:  93 Civic CX w/ B16A ,T3/T4 Turbo
Rep Power: 31 scottp11 is just really nicescottp11 is just really nicescottp11 is just really nicescottp11 is just really nice
Send a message via MSN to scottp11 myspace
I'm getting a B18 LS motor, which I plan to put a B16 head on... Eventually when I get enough money... So until then, which ECU should I use? (The motor does not come with stock ECU) Thanks for your time and help.
93civicCXB16A...T3/T4 turbo
00civicSI...CRVtec
93integraLS...GSR
My build thread! : http://nwp4life.zeroforum.com/zeroth...d=27937&page=1
scottp11 is offline   Reply With Quote
Old 08-30-2003, 03:17 PM   #2
scottp11's Avatar
Also, it's going in a 97 Civic EX, which is already wired for Vtec... Thanks
00civicSI...CRVtec
93integraLS...GSR
Old 08-30-2003, 10:21 PM   #3
Import King of Irvington
R.E.Developement's Avatar
Rep Power: 15 R.E.Developement is an unknown quantity at this point
get a jdm pr3 ecu
my team aint never scared cause we build seriousness.
forever Possessed Imports
R.E.Developement is offline   Reply With Quote
Old 08-31-2003, 12:25 PM   #4
Rep Power: 13 possessedimports is off the scale
Send a message via AIM to possessedimports
possessedimports is offline   Reply With Quote
Old 08-31-2003, 03:17 PM   #5
Rep Power: 27 SleEPeR_CRX is off the scale
dont build Ls vtec. a guy at the local track was running 15.3's on his LS/Vtec what was built. all internals done, blueprinted and balanced, i/h/e, msd, hondata, cams springs retainers. the only problem was it was an LS tranny. but shit, thats worse than my LS in a crx, and im running high 14's. If honda didnt make a ls/vtec it probably wasnt ment to be.
Sleepers Are the Only way to Go.
1990 CRX Si
B18a(92) CAI/E, Gutted, ACT clutch/pressure plate/13lb flywheel, Crower 403 Cams, Titanium Valve springs & Retainers, Blockguard, Head Milled 20 thou, 9.8:1 Compression, AEM cam gears.
1/4 = 14.73
60' = 2.48
trap = 95.03mph
Soon to get: Header, Slicks
Future 13 second all motor LS!
SleEPeR_CRX is offline   Reply With Quote
Old 08-31-2003, 05:46 PM   #6
scottp11's Avatar
What?...
00civicSI...CRVtec
93integraLS...GSR
Old 08-31-2003, 06:06 PM   #7
If built properly with good parts internally then the LS vtec is fine, it's when people take the cheap route to build it and literally just slap shit together, and don't block off with the proper hardware.
Chances are that kid was a shitty driven or maybe he was running it for the first time ever.
I ran two different b16s in my eg and like my sig says there was a huge difference in both, i used completey different components on the second project and with slicks netted a full second lower et. BUT, the first time I ever took the first project out to the 1320 I started with runnin a 14.7 and eventually hit 14.3 at the end of the night, with the more powerful second motor my very first time to the track I hit a fucking 15.7 with a 3.5 60ft time, and that motor I eventually got to run 13.3 with slicks.
So it just goes to show you that yes it takes time to learn how to properly drive your car and learn how to drive properly.
Milan
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 08-31-2003, 06:07 PM   #8
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
And a PR3 won't plug into a 97, an OBD II P30 would run it.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 08-31-2003, 06:14 PM   #9
you could also do this:
obd2-->1 conversion, P28 w/ ITR base map, hondata.
that would nice
Milan
Old 08-31-2003, 11:14 PM   #10
scottp11's Avatar
Will the P30/P28 still run the LS motor before I Vtec it? I don't want to have to buy 2 ECU's...
00civicSI...CRVtec
93integraLS...GSR
Old 09-01-2003, 12:04 PM   #11
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
Any time that you want to stop spreading this bullshit is fine. THe more you spout the more you affirm that you are indeed a stupid n00b.
If you are running a Honda ECU with no tuning device or the ECU + a VAFC start with the P72.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 09-01-2003, 03:01 PM   #12
scottp11's Avatar
Thanks lsvtec, its good to hear from someone that has actually done the swap... Thanks again. P72 it is.
00civicSI...CRVtec
93integraLS...GSR
Old 09-07-2003, 02:15 AM   #13
Rep Power: 13 dmxbmx is off the scale
Send a message via AIM to dmxbmx
ok ive had 3 ls vtecs over the past 1 1/2 years and i always sent[quote] my computer to Hondata to get chipped...But recently i had a friend the but a chip burner and we decided to try it on my old crappy ls computer...we burned a Mugen chip made for a p28 and installed it on my car....with the aid of a nitrous arming switch to activate vtec...i was very suprised at the outcome...the p28 chip pulled harder and faster then the Hondata comp. But i wouldnt recomend running a stock vtyec computer on an ls/vtec send the computer out to get chipped and youll definatly notice the results
94 del sol ls vtec
standing et 13.68 @ 101 with nitrous
dmxbmx is offline   Reply With Quote
Old 09-09-2003, 08:15 PM   #14
scottp11's Avatar
Will it be alright to run a Vtec ECU on a non-vtec motor? Just not having the vtec wires hooked up until I get the B16 head? Help!
00civicSI...CRVtec
93integraLS...GSR
Old 09-09-2003, 09:54 PM   #15
it will be ok ive done it to my friends car and nothing happened. it will just bring your rpms up to 7400.
Old 09-09-2003, 11:49 PM   #16
lsvtec's Avatar
Um, no. If you don't hook up the VTEC solenoid you are going to get a CEL. And the ECU will go into limp mode. You will have a fuel cut earlier than the LS ECU and more than likely you will see diminished fuel economy. Don't bother running the VTEC ECU until you have the VTEC head, you won't gain anything.
Old 09-10-2003, 03:32 PM   #17
hello i didnt say that i will give u a push. i said that it will work
Old 09-10-2003, 04:41 PM   #18
lsvtec's Avatar
But you failed to mention that it is an incredibly bad idea.
Old 09-10-2003, 07:52 PM   #19
hmmmmmmm true
but thought that it was the only ecu he has
my bad
Old 09-17-2003, 07:44 PM   #20
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
p28 / hondata = fast.
http://www.hondaswap.com/~pills
look at my setup.
pills_PMD is offline   Reply With Quote
Old 09-17-2003, 10:04 PM   #21
scottp11's Avatar
is there a way to bypass the Vtec soleniod so that I don't get a CEL? Like I said, I don't really wanna buy 2 ECU's.
00civicSI...CRVtec
93integraLS...GSR
Old 09-18-2003, 12:21 AM   #22
well you could always sell the unit that you bought,
and pleae people no butt dyno posts...
Old 09-18-2003, 01:39 PM   #23
Rep Power: 17 quicksi is off the scale
Send a message via AIM to quicksi
Now is the P28 or P30 OBD1 or OBDII? What if someone wants to do an LSVTEC and wants to retain OBDII for emissions testing purposes? Like here in Mass, we now have unbelievably strict emissions testing, and if they find an OBDI ecu that they can't plug directly into, automatic fail and $2000 fine.....can you run an OBDII ECU? or can you just throw in an OBDII ecu when it comes time to test once per year?
99 Honda Civic Si - Powered by 1.21 Jiggawatts of electricity
quicksi is offline   Reply With Quote
Old 09-18-2003, 09:02 PM   #24
scottp11's Avatar
But what about the Vtec CEL? It don't really care if I have to get a wiring harness conversion to OBDI cuzz my car is OBDII now. What I'm saying is I don't have an ECU right now, but I do have the B18B. I will eventually frank it, but not for atleast 6 months. I don't really want to buy a non-vtec ecu, then 6 months later buy a vtec ecu.... thanx for all the help.
00civicSI...CRVtec
93integraLS...GSR
