I just purchased an edelbrock 65mm throttle body but the throttle body seem hard to pull. I reved the engine up to 8k RPM and the throttle plate only open 25% not even 3/4. the spring coils on the throttle body are really tight and I assumed this is what cause it. I unlock the nut and loosen the spring coils on the throttle and same thing happen,the plate wont open fully. Any help or suggestion?
I am not in2RACING, RACING is Me! 96 cx hb with 98 JDM GSR, IB probe 12:3:1 7.1cc pistons, IB ultralite rods, skunk2 stage2 camshafts, valves, springs, retainers, cam gears, skun2 intake manifold, Eldelbrock 65mm throttle body, 4-2-1 DC, Quaife LSD, Findaza flywheel, Fsudo cat back with OBX high flow cat, a valve job with light port and polish, hodata s200, walbro 190 fuel pump, RC370cc injectors, and AEM fuel rail & regulator, NGK spark plug wire. STOCK BEST ET: 14.7 AT 95.3 mph. WITH MODS BEST ET: 14.2 AT 99.8 MPH |
well I am waiting for mine to come in, but is the valve hitting the inside of the manifold?
---------------1.7Ltr IB Spec Turbo Monster !!!--------------- '95 EJ Coupe, B16A Swap bored to 84mm with GE HD Sleeves,IB Spec JE Pistons,IB Spec SCAT H-Beam Rods,Type R LSD Trans,AEM Adjustable Cam Gears,Fluidyne Radiator, RC 750cc Injectors, AEM EMS Standalone With AEM Wideband UEGO O2 Controller, GM 3BAR MAP Sensor,GM Boost Control Solenoid,Turbonetics Stage 5 62-1 Turbo,2.5" Custom Exhaust, HKS SSQ BOV,Trust Type 31 Intercooler,ACT Streetlite Flywheel,ACT Streetdisc,ACT Xtreme pressure plate,Complete Energy Suspension Kit, 17" Katana Racing rims,Falken GRB FK451 225/35ZR17. -------Daily Driven,Full Interior,Complete Sound System------ ------------------------Certified Sleeper---------------------------- <a href=\"http://home1.gte.net/res0gy53/CARSWAP%20PICS.htm\" target=\"_blank\">My swap Pics (56K Beware)</a> |
is it physically not openening 100%? or is the percentage you read on your VAFC? could be the TPS is not calibrated?
2005 Mitsubishi Lancer Evolution 8 2004 BMW 325i 2000 Mercedes Benz ML 430 1994 Honda Civic Del Sol VTEC (race kaa) |
#5 |
as i mention on the post, I reved the engine up to 8000 RPM and the throttle plate only tilted a little bit, approximately 25%. When I manually open the throttle body, there is a scraching sound, which I assume to be the springs, but I was wrong, it was the throttle plate that make the noise. there is no visible scrach on the inside of the throttle body, but the steam that hold the throttle plate with two tiny screws seem to be harder to pull by the cable than the stock. I sent the throttle back and hopefully they exchange for a new one or refund me back. thanks for the helps!
