Facebook Twitter
Engine Balancing
This is a discussion on Engine Balancing in the Engine Building forum
So i got the unorthodox PS/AC eliminating underdrive crank pulley, and the guy at the machine shop says i need to have the engine spun balanced since the crank pulley is "part of the engines balancing". I thought they balanced the engine by adding weights ...
Old 10-18-2006, 02:12 AM   #1
Default Engine Balancing
So i got the unorthodox PS/AC eliminating underdrive crank pulley, and the guy at the machine shop says i need to have the engine spun balanced since the crank pulley is "part of the engines balancing". I thought they balanced the engine by adding weights to the flywheel, but he indicated that the holes that circumferate the crank pulley have something to do with the engine balancing. If this is the case then how can they call this underdrive pulley a "bolt on performance part" if you gotta rebalance ur engine to make it work. If anyone knows whether i actually need to spin balance my engine to put this pulley on, please enlighten me, because i would rather not as it is quite expensive. Thanks.
Go to work, Act normal, Believe the News, Save for your old age, Obey the Law
Repeat after Me: I am Free
klyph is offline   Reply With Quote
Old 10-18-2006, 03:19 PM   #2
Come on, i posted this last night, i expected an answer by morning. Bump.
Old 10-18-2006, 03:47 PM   #3
lsvtec's Avatar
It is part of the rotating assembly and IIRC the unothrodox pulley does not have a harmonic balancer so if it isn't balanced properly it will vibrate like crazy. It might be balanced from the factory, but I wouldn't trust it. IMO you should have it all balanced.
lsvtec is offline   Reply With Quote
Old 10-18-2006, 04:01 PM   #4
Ok, I'll get it balanced. At least now i can justify installing a lighter flywheel!
Civic engine swap Penguine Civic and CRX - EF 11 04-12-2009 10:05 PM
Engines with the fastest piston speeds asmallsol Members' Lounge 10 08-25-2006 08:01 AM
light weight engine SolPWR Members' Lounge 31 12-11-2003 04:09 PM
ecotec tweakman Members' Lounge 22 09-29-2003 02:23 AM
What is double clutching? Calesta General Tech Articles 0 12-27-2002 02:06 PM
© 2001-2013 HondaSwap.com
