engine build help b18b1 in 97 ex civic
Old 01-02-2008, 07:02 AM   #1
elvis8310's Avatar
Ride:  97 EX with B18B
Rep Power: 3 elvis8310 is on a distinguished road
Default engine build help b18b1 in 97 ex civic
I am building a b18b1 obd1(already in the car) with turbo. I am using the greddy kit with a fmic. I have an aem fuel rail ,330 injectors b&m fuel pressure regulator with vison 6 bolt adjustable cam gears with gates racing turbo belts(all of them). I have a -6an fuel line from the filter to the rail, msd extermal blaster ss coil and msd dizzy cap what else can i do to my car to get the most out of the power? Yes, i can do the work myself with no issues( i did all the work so far myself). I just want it reliable but fast I have the German autobahns to drive on so speed limits are not an issue. No, I don't want to hit 170, just fast enough to have fun. I know the tranny is weak and the clutch needs upgraded but not sure which one(clutch) to use. I also am having my intake manifold ported and polished to match the throttle body(68mm). Oh and yes I have a true 3 inch cat back exhaust, I have the thermal research turbo one, stock cat for now.
I also did the suspession right. skunk2 PRO SERIES PLUS front camber kit, Energy Suspension Bushing Kit, ksport lower control arms, Ksport Rear Toe Kit so far. I will buy my full coilovers and braces this week just not sure which ones I want. Stock ecu also as seeing I have not found any tuners over here yet.
This what I have so far but want more so please stear me in the right direction.
elvis8310 is offline   Reply With Quote
Old 01-02-2008, 07:58 AM   #2
dtob's Avatar
Rep Power: 9 dtob is an unknown quantity at this point
What do you want to know?
dtob is offline   Reply With Quote
Old 01-02-2008, 10:47 AM   #3
elvis8310's Avatar
were to get more power out of the car? Were to send my ecu to get chipped or how to do it with what? Is there anything I have left out to make the most of my power. oh, and how do you cut a valve cover.
Old 01-02-2008, 01:36 PM   #4
żUnKnOwN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 92 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
what are you cutting a valve cover for and where are you doing it?!?also what is done to the internals of the motor??there are many places to have an ecu sent to be chipped,you can go to rywire.com or one of my boys got a complete chipped ecu with a basemap for his car,,it depends on how much cash you have,what your power goals are,and if its a daily driver,also the tranny you use depends on what you want in the end..
do you want a car that will reach 120 in a matter of seconds or do you want a car that will reach lets say...160 in a matter of minutes...(these arent real numbers just aroundaabout)as for clutch stage 2..should suit your need..get act,exedy,and zoom even makes good products
http://hondaswap.com/auto-multi-medi...st1144603.html <my CRX
R.I.P BEN LEE2/24/08 we love and miss you
R.I.P Rex 8/18/08 coolest dog ever!!!
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
INJEN78 is online now   Reply With Quote
Old 01-02-2008, 02:41 PM   #5
elvis8310's Avatar
I want to cut the valve cover so I don't have to pull it off to adjust the cams. I do alot of road courses and high way driving. As far as power goal it will be around 200 to 250 marker. Engine rebuild will not happen till I move back to America next year. I can do the head with new valves and cams but thats it. it is way to much money over here in Germany to port and polish and multi angle valve jobs. I am looking at the crower turbo cams but not sure which valves to use with these cams I will be calling crower to ask for advice on this set up for sure.
Old 01-02-2008, 05:13 PM   #6
The Kicker of Elves.
Blanco's Avatar
Rep Power: 217 Blanco has a reputation beyond repute
Blanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond repute
Set your cam gears on the dyno and leave them there. It might feel like you're picking something up, but even a 2* adjustment past optimum will lose you a significant amount of power. Unless, of course, you're one of those people who feels the need to drive down the highway at peak power in 3rd gear.
What do you mean what valves to use with that cam profile? Use whatever valves you want, as long as you have the valve/valve and piston/valve clearance you're fine. A few measurements will tell you all you need to know about that.
Don't misinterpret what I say.
Originally Posted by The Secrets of Body Language
93% of communication is done through body language.
Originally Posted by http://humanresources.about.com/od/interpersonalcommunicatio1/a/nonverbal_com.htm
One study at UCLA indicated that up to 93 percent of communication effectiveness is determined by nonverbal cues. Another study indicated that the impact of a performance was determined 7 percent by the words used, 38 percent by voice quality, and 55 percent by the nonverbal communication.
Originally Posted by Shawn Pelton
It's not good to be a drummer unless you got some bad motherfucker up inside you.
Blanco is offline   Reply With Quote
Old 01-02-2008, 05:18 PM   #7
żUnKnOwN?
INJEN78's Avatar
Ride:  91 CRX si
250 is easy with your setup..just the turbo and tune will get you alot of power..
GOOD FAST CHEAP,
Old 01-03-2008, 02:11 AM   #8
elvis8310's Avatar
i just want the valve cover cut so the tuner spends less time taking the cover off when tuning. As far as the valves go I keep reading about high lift valves but by the specs of the cams I don't think I need those. I am calling crower today to get a full setup from them I.E. cams, valves and springs that all work together perfectly. I just need to check on valve guides and seats next so I can start to rebuild the head while all my powder coating and body work is being done. Also what size head gasket should I use and from which company. i have looked into Cometic Head Gasket , METAL HEAD GASKET, COPPER HEAD GASKET, BUDDY CLUB HEAD GASKET and Mugen Head Gasket. The stock is a 3 layer and I have scene 2 layer or multi layer and so on. I get the thinner it is the more compression it makes. What is the best material for boost in your alls opinion?
Old 01-03-2008, 05:02 AM   #9
Blanco's Avatar
Wow, you're going on half information. You're reading about high valve lift, not high lift valves. BIG difference. You don't need new valves unless there's something wrong with your stock valves. Newbies always seem to think they need to change valves when they changes cams. Not so, at all. The valves seats are part of the cylinder head, so you won't be checking on or buying them from anywhere. Look up "valve job" to see what that's about. The best head gasket for your goals is OEM Honda/Acura. You can slap a turbo on a bone stock B18 and get the horsepower goal you're looking for and it'll still be reliable depending on the tune.
Old 01-03-2008, 05:25 AM   #10
elvis8310's Avatar
Cool works for me. I do need to read more about valve jobs before I do this. I have read that you can flout a valve if you take the rpm's up to high so at least wanted to install dual valve springs to stop that from ever happening. I just thought the stock cam spec were not designed for forced induction so why not buy a set that are designed for it. I have to leave the bottom half stock till the car goes back to america so I can build it right. There are to many rules over here to get it done the way I want it.
Old 01-03-2008, 05:35 AM   #11
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 121 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
Blanco is correct.
I made right around 240 with my 60/63 budget build.
I second going with an OEM HG
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
=I love this truck
2007 Civic
=Not sure what the future holds for this
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 01-03-2008, 05:46 AM   #12
elvis8310's Avatar
Ok, so the cams and dual valve springs are not needed? Will the springs stop valve flotting(I think this is what they call it) if I take the rpm to high?
Yes, That is me on the bike in my Avatar.
Old 01-03-2008, 06:14 AM   #13
The Trisexual
It'd really not needed for your power goal. If you want a slightly higher RPM get em. And cams will net higher gains.
Current Rides
=I love this truck
2007 Civic
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
253whp
Old 01-03-2008, 10:16 AM   #14
Blanco's Avatar
When you upgrade past a "stage one" cam profile you risk valve float, so you upgrade the valve springs at the same time. Like b18b1 said, you don't need aftermarket cams but they will make more power over stock cams.
Old 01-03-2008, 10:25 AM   #15
dtob's Avatar
+1
You can turbo your stock B18 and get the power you want. Just make sure you have proper fuel management and a good tune and you will be fine.
Have fun!
Old 01-03-2008, 03:01 PM   #16
elvis8310's Avatar
Well, for fuel system so far I have an AEM fuel rail. -6an fuel lines and B&M fuel presure regulator also parts from the Greddy Trust Turbo kit=310cc Injector, Fuel management (E-MANAGEMENT).
Old 01-03-2008, 05:32 PM   #17
Blanco's Avatar
How are you going to get the extra fuel to the rail?
Old 01-04-2008, 01:04 AM   #18
elvis8310's Avatar
Sorry I forgot to post my walbro 255 pump.
Forum Jump
Engine mount problems between 91 Civic Si engine into 93 Civic Ex Body civvik Civic and CRX - EF 1 09-03-2007 08:58 AM
****GARAGE SALE..SOHC DREAM...COME ONE COME ALL**** whos_the_master Parts: For Sale/Trade/Wanted 24 02-17-2006 10:21 PM
ecotec tweakman Members' Lounge 22 09-29-2003 03:23 AM
Need some help with Trim Names YangpaNemsay General Tech and Maintenance 7 08-31-2003 04:43 PM
