engine wont start
Old 02-02-2007, 05:46 PM   #1
can you say 260 whp N/A??
94_gs-r's Avatar
Ride:  94 inegra gsr
Rep Power: 11 94_gs-r is an unknown quantity at this point
Send a message via Yahoo to 94_gs-r
Default engine wont start
so i got the motor back into my car it tries to start and it backfires and thats about as far as it will go... do you think my timing is off? maybe a ground or something.. i have the p72 ecu so it doesnt have the light on it how can i check to see if im throwing a code?
buy my motor!!! check out link.
http://hondaswap.com/parts-sale-trad...ression-93212/
94_gs-r is offline   Reply With Quote
Old 02-02-2007, 08:50 PM   #2
Rep Power: 59 hcivic.com is on a distinguished road
back fire means fuel so I would check that you have full fuel pressure and your timming ?
hcivic.com is offline   Reply With Quote
Old 02-03-2007, 01:02 AM   #3
I wear stretchy pants
Taco15's Avatar
Ride:  chevy s-10
Rep Power: 217 Taco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
myspace
Originally Posted by Blanco View Post
If it was a ground it wouldn't try to turn over at all.
Sounds like timing.
sound like your a couple teeth off. Or you plug wires a mixed
Its fashion man. The chicks you see walking down the runway dont wear practical clothes, they were something that was designed to make a statement. THat statement in turns influences and shapes other peoples designs and ideas.
Same thing with cars. Except with no attractive women... and a lot more gayness.
Taco15 is offline   Reply With Quote
Old 02-03-2007, 04:13 AM   #4
94_gs-r's Avatar
Ride:  94 inegra gsr
checked all the plug wires bought bran new ones and new spark plugs, i played with the ignition timing a little and it backfired more, its firing out of the tb though so the valves are opening and closing at the wrong time, so i figure maybe the distributer is 180' off and a mechanic i talked to said the same thing i took it off and rotated it but it will not plug in that way... it can only go the one way into the back of the cam...
the backfire will not harm my engine will it.
Old 02-03-2007, 04:56 AM   #5
94_gs-r's Avatar
Ride:  94 inegra gsr
the order fron distributer to cam gear is 4-3-2-1 correct
Old 02-03-2007, 10:49 AM   #6
Ancient Member
welfare's Avatar
Ride:  RHD EG6 jrsc b18c :)
Rep Power: 29 welfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the rough
Send a message via AIM to welfare
check the pic below, your number 1 cylinder is closest to your belt side of the engine.
welfare is offline   Reply With Quote
Old 02-03-2007, 10:51 AM   #7
Ancient Member
welfare's Avatar
also, the lugs on the distributor that engage the cam are offset so that you can't install it 180 out.
Old 02-03-2007, 02:49 PM   #8
94_gs-r's Avatar
Ride:  94 inegra gsr
k i got it running and idles fine but the throttle feels funny... it will drive like normal but feels gutless and in letting the clutch out i push the gas and it wants do die but i can her the tb opening... and the check engin light comes on
Old 02-03-2007, 03:05 PM   #9
94_gs-r's Avatar
Ride:  94 inegra gsr
almost sounds like its not getting fuel but why would the check engine light come on
Old 02-04-2007, 12:00 AM   #10
94_gs-r's Avatar
Ride:  94 inegra gsr
adjusted the ignition timing rund and drives fine with no hesitation but now it feels gutless there is absolutely no torqu. i have put 100 miles on it to set the rings but at any rpm if i push on the gas hard there is barely a change, very slow acceleration and check engine light still on, i went to a few diff places and read in a chiltons that the plug i need to use to read the code is above the ecu or way under the dash by the center console.. couldnt find it neither could they.
its a 94 gsr, can any of u help me out?
Old 02-04-2007, 04:32 AM   #11
94_gs-r's Avatar
Ride:  94 inegra gsr
yes checked that, i need a quick lesson on how to read those codes, from what im seeing it flashed 2 times the blinked really fast 3 times and kept doing that
Old 02-04-2007, 04:48 AM   #12
94_gs-r's Avatar
Ride:  94 inegra gsr
damn... so do you have to fix the one code in order for it to move on to the next?
i knew it would be the knock sensor... i replaced it i must have got a bad one... fuckin e-bay..
so i dont pay attention to the first few times it flashed because that where it starts rite? so wait for a long pause and then it starts.. long flash means its 1-9 and if its followed by short flashes then its btw 10-whatever..
Old 02-04-2007, 11:06 AM   #13
Ancient Member
welfare's Avatar
Switch your map sensor and your TPS wires (identical plugs) you prolly got them mixed up.
as far as the knock sensor you have to run a shielded wire from the ecu to the knock sensor in order to make it work.
Old 02-04-2007, 12:17 PM   #14
GSRCRXsi's Avatar
Rep Power: 88 GSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of light
this is the motor you had built at the machine shop, the build you talked about in your other hundred threads? why are you driving it untuned and with codes?
driving it untuned you may have done irreverable damage. too lean, and the pistons expand into the walls, scorring them. too rich and you wash the oil off the walls losing lubrication and accelerating wear.
i REALLY hope you havent been driving without an AFR meter of some kind and and some way of adjusting your fueling.
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
Old 02-04-2007, 11:58 PM   #15
94_gs-r's Avatar
Ride:  94 inegra gsr
it is the knock sensor car is in safe mode and car is parked till i get a new one then going to re-time the engine. thanks for the help guys
Old 02-05-2007, 07:57 PM   #16
Ancient Member
welfare's Avatar
not to try to knock off what anyone else has said, I agree with everyone else, but the knock sensor will NOT put a honda in safe mode. . . My brother drove on a disconnected KS for a month before he got a new one, there was no change in how the vehicle performed. Granted I totally understand that the KS retard the engine timing if it detects detonation and he shouldn't have driven the car hard, but under NORMAL driving the vehicle will not harm itself.
As a matter of fact, I don't think the KS even gets looked at by the ecm until the engine engages VTEC, I could be wrong, but I have only known the CEL to come on for KS if the enigne is revved high.
Also, I noticed that you have mugen chip listed and greddy fuel management listed, neither of which has a safe mode that I am aware of.
Tell me, does the car still bog if you put in the stock ecu???
Check the plugs that I mentioned before, I still think that your problem lies there with the bogging.
as far as the knock sensor, did you run a shielded wire to it? The wire needs to be shielded because it can ger interference from just about any other wire that it is near (also happened to me), a shielded wire has braiding around it that needs to be grounded so that no interference gets in it. (alot like spark plug wires)
check into this stuff and then let me know how it goes.
Old 02-06-2007, 07:42 AM   #17
Ancient Member
welfare's Avatar
Also, check your valve lash.
Old 02-06-2007, 08:03 PM   #18
94_gs-r's Avatar
Ride:  94 inegra gsr
1 tooth onn intake and 2 off exhaust, purrs like a kitten
Old 02-06-2007, 08:09 PM   #19
Taco15's Avatar
Ride:  chevy s-10
myspace
huh guess i was right. Glad you got it going
Old 02-08-2007, 12:53 AM   #20
94_gs-r's Avatar
Ride:  94 inegra gsr
im tuning on chrome, now... TO THE HEAD HAHA
im having alot of help on the head build though from ppl that actually know what there doing, for this being all done in my garage and basically doing it alone cant say i did to bad...
Jdm & Usdm Motor Swap Answers civicsi1415 HYBRID -> EG-EK / DC 15 08-01-2008 01:15 PM
first start of the new engine ^crx^ HYBRID -> ED-EF / DA 0 07-06-2004 04:58 PM
Assembling an LS/VTEC pissedoffsol General Tech Articles 1 06-04-2004 11:17 AM
engine wont start assman General Tech and Maintenance 7 02-26-2004 12:19 PM
Engine cranks, but car won't start sbaker0421 General Tech and Maintenance 20 01-23-2004 12:04 PM
