Ex intake and TB on DX
Old 05-15-2004, 11:10 AM   #1
Rep Power: 12 Riley37 is off the scale
I am want to swap my DX downdraft style intake and TB for an EX side draft set up. First, is it worth it? Will I gain anything? Also, do I need new sensors, injectors, fuel rail or any thing else? Is this a faily easy bolt on deal.
Thanks
Mike
Riley37 is offline   Reply With Quote
Old 05-18-2004, 01:45 AM   #2
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Bump for this ain't swap related y0!!!
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 05-18-2004, 04:15 PM   #3
It's kinda a swap, a mini-mini-me swap. Symantics...!
How do I move it? What would the best forum be for this question?
Thanks
Old 05-20-2004, 01:25 AM   #4
Can I get some help? Or am I still in the wrong board?
Thanks!
Old 05-20-2004, 06:30 PM   #5
Rep Power: 12 katman is off the scale
Thanks
Mike
yes, this is possible to do.
You would need to get a 96+ EX intake manifold (I/M) off an AUTO model though. Reasonbeing is the auto version of the EX I/M uses a 3-wire IACV which is what you need to use to satisfy your DX ecu. 5speed EX I/M use a 2-wire IACV which your DX ecu would NOT like at all.
I suspect you'd need the complete auto EX I/M w/throttlebody, sensors, possibly the throttle cable (not sure if your DX cable is compatible), and fuel rail. You may be able to reuse your DX fuel rail though. reuse your DX injectors and mounting hardware..
katman is offline   Reply With Quote
Old 05-21-2004, 03:44 PM   #6
Thanks for the info. Is this upgrade worth while, I mean will I see some performance improvements. Also, are the EX injectors the same as the DX or do I need to use DX injectors to be compatible with the ECU?
Thanks again
Old 05-21-2004, 04:42 PM   #7
Thanks again
I'm pretty sure its worthwhile, along with upgrading to an EX tranny as well. You'll probably gain some good torque over the DX manifold.
And you can/should reuse your DX injectors, because you'll be reusing your DX ecu. AFIAK, the EX & DX injectors are of same exact spec...
