Exedy Vs ACT
Old 10-28-2005, 02:11 PM   #1
Rep Power: 19 CiViC_SOHC is off the scale
Send a message via AIM to CiViC_SOHC
Ok so im going to turbo my D16Z6 that came out of a delsol Si. I need to know what kind of clutch I would need. I am looking for about a 221ft/lbs that way when I start doing everything big I dont' have to worry about it. I was wondering what you guys think. I have found on ebay that you can get a stage one exedy clutch and flywheel for $551. I havn't heard bad about both clutches I heard its just personal preference. Is this true or is one better then the other? Thanks for the info.
-mike
1992 EG8 Civic Sedan / '98 D16Y7 swapping a D16Z6...TURBO!
Support the local Performance shop. <a href=\"http://aeiperformance.com/\" target=\"_blank\">AEI performance</a>
CiViC_SOHC is offline   Reply With Quote
Old 10-28-2005, 02:35 PM   #2
Rep Power: 12 turbo99 is off the scale
<div class='quotetop'>QUOTE(CiViC_SOHC @ Oct 28 2005, 01:11 PM) Quoted post</div><div class='quotemain'>
-mike
[/b][/quote]
I wouldn't buy Exedy. My bro's teg has an Exedy and first gear doesn't pop in smooth. You have to force it in. Other than first gear, it works fine. I'm certain that it's the pressure plate because I've done a couple clutch jobs and I'm sure I installed it right. When I installed an ACT on my car, I haven't had any problems with it. It works great. Get ACT.
turbo99 is offline   Reply With Quote
Old 10-28-2005, 02:42 PM   #3
Rep Power: 29 VTECPOWER is off the scale
Send a message via AIM to VTECPOWER
Excedy, is what i have, stage 1, stock feel, grabs nicely gear to gear.
DB8 450whp project......
VTECPOWER is offline   Reply With Quote
Old 10-28-2005, 03:22 PM   #4
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
[img]style_emoticons/<#EMO_DIR#>/withstupid.gif[/img] [img]style_emoticons/<#EMO_DIR#>/withstupid.gif[/img] [img]style_emoticons/<#EMO_DIR#>/withstupid.gif[/img]
x10
http://pandora.com/
Old 10-28-2005, 03:31 PM   #5
Rep Power: 20 smooth_criminal is off the scale
go with act, and if your boosting the car don't get a light flywheel, the mass of a stock flywheel will put more load on the motor and spool the turbo qiucker then if you had a light fly.
You hate me because i'm different;
I hate you because your all the same!
G-Driver.
smooth_criminal is offline   Reply With Quote
Old 10-28-2005, 03:36 PM   #6
Stylus DJ Extraordinaire
integraslut78's Avatar
Ride:  ?????????
Rep Power: 38 integraslut78 is on a distinguished road
It's all personal opinion I say go with the ACT HDSS I have heard bad things about Exedy, but again it's all personal opinion.
DC Squad Member # 0631
I used to have my rides in this section but there are too many thieves out there trying to jack. I HATE THIEVES
integraslut78 is offline   Reply With Quote
Old 10-28-2005, 03:42 PM   #7
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 156 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
<div class='quotetop'>QUOTE(turbo99 @ Oct 28 2005, 01:35 PM) Quoted post</div><div class='quotemain'>
-mike
[/b][/quote]
[/b][/quote]
that's a tranny problem, has absolutely nothing to do with what clutch he has.
as far as Exedy VS ACT goes, I have been running my Stage 1 Exedy for 30K plus miles and it's still going strong. I never even broke it in. Just installed it and started ripping threw gears.
and for the record, no clutch company goes by "stages" they go by street, street/strip, race only, ECT... it's just easier to explain when you call them stages.
Real Eyes Realize Real Lies
B16RacerN2NR is offline   Reply With Quote
Old 10-28-2005, 04:01 PM   #8
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
I put exedy stage 1's in everything I drive. I simply LOVE them, never had an issue.
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 10-28-2005, 07:33 PM   #9
Rep Power: 11 BigBoy is off the scale
Both are a great choice.
People who have problems with the exedy clutches are people who didnt install them properly.
BigBoy is offline   Reply With Quote
Old 10-28-2005, 08:02 PM   #10
<div class='quotetop'>QUOTE(BigBoy @ Oct 28 2005, 06:33 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I installed it properly. Like I said, I've done clutch installs before and never had that problem. I can assure you that it definitely isn't the tranny. The tranny was working perfectly before the clutch install. I've even taken the car to professional shops and they agree that the Exedy pressure plate is faulty. There's no way I'm going to buy Exedy again. A clutch job takes a lot of time and I don't wanna tear the tranny down again just to replace a part that should have been working 100% the first time. I've never heard anything bad about ACT so do whatever you like. It's your car and money.
Old 10-28-2005, 08:13 PM   #11
<div class='quotetop'>QUOTE(integraslut7 8 @ Oct 28 2005, 02:36 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Any reliable websites that I can buy this from? I still need to get a tranny first but I am just looking for my clutch to go with it.
Old 10-28-2005, 08:29 PM   #12
Ride:  ?????????
You could google it if you want or check out www.robearracing.com
Good Luck mang.
Old 10-29-2005, 01:22 PM   #13
Rep Power: 11 bambam is off the scale
Send a message via AIM to bambam
<div class='quotetop'>QUOTE(turbo99 @ Oct 28 2005, 08:02 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
[/b][/quote]
Exedy Pressure plate was not faulty. Bet you didn't know that "EXEDY" makes all the stock clutches and pressure plates for all the hondas? Yep, the OEM clutches are made by "Daikin"...aka...EXEDY.
Why would Honda trust them?
I've had my exedy stage one for 25k and it still grabs like day one. Never broke it in either. I swear by their clutches.
As for ACT's....my boy's RSX Type-S lasted one day on the ACT clutch at the track w/ a 100 shot....lol.
Everyone is going to have stories about other people's clutches...but in the end you gotta think to yourself, why does honda use "exedy"?
Plug and play swap harnesses, vtec subharnesses, conversion harnesses, etc. The best quality at the absolute lowest price!
Please visit the store:
www.hybrid-creations.com
'88 Honda CRX
All motor lsvtec. 12.7 @108
allmotor > boost
bambam is offline   Reply With Quote
Old 10-29-2005, 02:39 PM   #14
<div class='quotetop'>QUOTE</div><div class='quotemain'>Exedy Pressure plate was not faulty. Bet you didn't know that "EXEDY" makes all the stock clutches and pressure plates for all the hondas? Yep, the OEM clutches are made by "Daikin"...aka...EXEDY.
Everyone is going to have stories about other people's clutches...but in the end you gotta think to yourself, why does honda use "exedy"?[/b][/quote]
Yes, I did know that Exedy makes Honda's OEM clutches. Just because they make Honda's OEM clutches doesn't mean that their entire product line is comparable. Their OEM products are good, but I wouldn't say their other stuff is. I had an Exedy myself, and it burned out in no time. I just never had any good experience with their products. But if you're happy with their stuff, good for you. Whatever makes you happy. Like I said, it's up to him to decide.
Old 10-29-2005, 05:48 PM   #15
formby's Avatar
yes because act uses stock clutch cores and modify them.....btw Ex main product are clutches...higher quality standards......imo
buy whatever you want.....
for the best Ex deal look up clutch city on ebay....he sent me the wrong clutch and replaced it 2nd day air for free....and it was my fault....
http://pandora.com/
Old 10-29-2005, 06:40 PM   #16
<div class='quotetop'>QUOTE(formby @ Oct 29 2005, 05:48 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Yep, clutchcityonline.com
that's where i got my clutch from...found it to be the cheapest there.
'88 Honda CRX
allmotor > boost
