f22/h22 hybrid
Old 10-01-2002, 11:27 PM   #1
Rep Power: 0 hondaman16lx is off the scale
hey, i have a 1991 accord lx with a nonvtec sohc 2.2 liter engine, is it possible to bolt on a dohc vtec head from a 2.2 liter h22 , if possible is it worth the trouble and will i really see an increase in power any help greatly appreciated thanx
hondaman16lx is offline   Reply With Quote
Old 10-01-2002, 11:31 PM   #2
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 67 lsvtec is on a distinguished road
If it is possible, it would not be cost effective unless you already have the H22 head. You would have to buy then entire H22 to get the head and at that point you might as wel just swap the H22 in. Besides the internals of the H22 are stronger, the compression is higher, ect.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 10-02-2002, 01:25 AM   #3
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
Rep Power: 529 pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
i've heard f it being done before, but i to, would not suggest it
Old 10-02-2002, 01:01 PM   #4
WRX Sellout
Ride:  2002 WRB Impreza WRX
Rep Power: 97 dohcvtec_accord is an unknown quantity at this point
lsvtec is right, just swap the whole damn motor. Better block internals and tranny.
This space left intentionally blank.
Old 10-02-2002, 01:09 PM   #5
rmerrell
Guest
Posts: n/a
Get a h22 block and head.. and the h23 tranny..
Old 10-13-2002, 04:40 PM   #6
Rep Power: 0 vxhatch is off the scale
i always thought that the sohc blocks werent wide enough to bolt a dohc head on one, i could be wrong.
vxhatch is offline   Reply With Quote
Old 10-13-2002, 05:56 PM   #7
lsvtec's Avatar
I think that it is possible, but why?
Old 10-14-2002, 10:52 AM   #8
WRX Sellout
Not always, but in this case, the F22 block will indeed hold the H22 head. But it's a question of why bother. The only time mating an F-series to an H-series would be worth it is in the case of the later-year F23 engines, to get the extra tenth of a liter displacement.
Old 08-13-2008, 03:16 PM   #9
Ride:  96 Accord
Rep Power: 0 Jrvalid1 is on a distinguished road
Default I've done it. I wouldn't do it again.
Yes it can be done. I have it done on my 96 accord. However, I have been thoroughly annoyed by the fact that since the h22 head is wider than the f22 block the outside of the oil return holes on the front and back of the block don't line up. If you want to see this exactly, go buy an f22 and h22 head gaskets and line them up. Besides the fact that you have to put about an 1 1/2" of JB Weld in the outer return holes near the timing belt to make it work at all without dumping oil down your block.
With an f22 head gasket, the engine leaks about a quart every two months. Not too much but annoying. Here is what else I had to change:
--I had to buy an h22 main crank timing belt sprocket ($50) and water pump and take the pulley off of the new water pump and press it on the old f22 pump (h22 sprocket on f22 pump)
--added length to the Intake Air Temp wire (about 12") because it is in another location on the h22 intake
--used the f22 Throttle body (I am turbocharged)
--bought the h22 timing belt
--had to jimmy-rig my power steering holder with only 2 bolts instead of 3
--And I still have a P1382 code because the h22 dizzy has a bad mag. sensor in it. To replace the sensor, I have to buy a new dizzy.
After all of this, it still leaks oil. So. My advice. Unless you want to be in a shop for a year and a half messing with this pain in the A**, don't do it.
I would just dump the entire motor if I hadn't just bored it out and put in toga rods and arias low compression (8.0/1) pistons. If anyone has a nice f22 head they want to trade for a h22 head with ferrara racing stanless steel valves, PM me.
Jrvalid1 is offline   Reply With Quote
Old 08-14-2008, 08:39 AM   #10
Ride:  91 civic DX
Rep Power: 3 Justin91civic will become famous soon enough
Do you realize that this thread is almost 6 years old.
Justin91civic is offline   Reply With Quote
Old 08-14-2008, 06:57 PM   #11
Ride:  96 Accord
Yes. Most of what I read about working on my car in these forums is quite old.
Old 08-14-2008, 08:03 PM   #12
nootrac22's Avatar
Ride:  daily driver working on 92 prelude 4ws
Rep Power: 103 nootrac22 has a reputation beyond repute
nootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond repute
Send a message via Yahoo to nootrac22 Send a message via Skype™ to nootrac22
Is it a record?
nootrac22 is offline   Reply With Quote
Forum Jump
hybrid seats in 91 civic PHOBIA Body / Exterior / Interior / Cosmetics 1 10-25-2004 04:09 AM
research paper, what do you think? 90 accord Members' Lounge 9 06-23-2004 12:11 AM
Hybrid Revolution Phone Number BryanPendleton Members' Lounge 1 01-06-2004 02:41 PM
B16/b20 Hybrid simonc Engine Building 3 05-21-2003 04:54 AM
f22/h22 hybrid hondaman16lx HYBRID -> BA-BB /CA-CD 1 10-01-2002 11:33 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
