Fuel system
Old 05-24-2004, 02:45 PM   #1
Rep Power: 16 Sed8ed is off the scale
Send a message via MSN to Sed8ed
I have spent the better part of this morning researching fuel system setups and I have gotten a little swamped with info... I'm not sure if I have gotten injectors that are too large for my setup or if they are too small... also I am not sure about my fuel pump either.
My new engine build is: 92 ls block, full rebuild with pr3 pistons, pnp 98 ls head, spoon 68mm throtle body, stock intake mani portmatched at both ends, crower 403's possibly 404's (haven't ordered yet), 75 shot wet nitrous system, hondata s200 (haven't ordered yet), other misc parts that don't really concern the fuel system
Fuel system so far: aeromotive fuel filter, 6an fuel line, aem fuel rail, accel 310cc fuel injectors, b&m fuel pressure regulator, fuel pressure gauge, 4an fuel line from fuel rail to nos fuel solinoid.
This is in a 97 civic hatch so right now I have the stock cx fuel pump, is this adequate or should I upgrade to a 190lph or a 255lph, if I need a larger one, how do I tell which one to get?
Any help would be appreciated, i'd rather find out now that i need different injectors or a bigger pump then when it's strapped on the dyno and I need to pay for a new dyno tune once I have bought the new parts
Thanks
'Due to budget cuts, the light at the end of the tunnel has been turned off.'
'Out of my mind, back in five minutes'
Originally posted by simba
Canada didn't become a communist state, it became a socialist country run by liberal housewives who think cause and effect is black and white.
Own a gun? Well, it's probably going to cause someone to be shot sooner or later. Better restrict them.
Own a fast car? Well, you're probably going to kill someone due to driving too fast sooner or later. Better give the police unlimited power to "convince" you to return it to stock, so you won't kill anyone. Freedom is subjective.
Sed8ed is offline   Reply With Quote
Old 05-26-2004, 12:00 AM   #2
Rep Power: 12 Floydy is off the scale
Send a message via AIM to Floydy
Since you upgraded the injectors would should probably upgrade the fuel pump. At least to a 190lph.
Daily Driver- 88 Rex with ZC swap. (Soon to have an ls/vtec)
Floydy is offline   Reply With Quote
Old 05-26-2004, 01:05 PM   #3
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
the 190 will be fine
