| | LinkBack | Thread Tools |
| | #1 |
| Senior Member Join Date: Mar 2006 Location: Tallahassee, FL
iTrader: 1 / 100% Ride: 1991 CRX Si
Rep Power: 49 | 1. What oil should I use? 20-50 Syn. blend? Full synthetic?(for break in and the rest of it's life) 2. Whats the best spark plugs to use that I can buy at Advanced auto? I think I should run 1 range colder plugs. Am I right? Thanks |
| | #3 |
Rep Power: 49 | So the normal range is 8? I think I'm going to use a little thicker oil. I was recommended by a knowledgeable friend that 2050 is good stuff. someone back me up? |
| | #4 |
| Senior Member | |
| | #5 | |
| learning in progress Join Date: Feb 2003 Age: 27
iTrader: 4 / 100% Ride: 00' Montero sport, 99' lsv civic
Rep Power: 94 | Quote:
and break in with regular 5-30 or 10-30 then use synthetic. ams oil is my fav | |
| | #7 |
| D Series FTL Join Date: Nov 2006 Location: Kansas City Age: 24
iTrader: 0 / 0% Ride: 1999 Accord EX Coupe - Daily
Rep Power: 7 | I agree, stick with 10w30 and you should be just fine. With that compression, you're best off running plugs 2 steps colder than the factory heat range, which would be the NGK TR7's. TR55's are factory heat range. |
| | #9 |
| I wear stretchy pants Join Date: Jan 2005 Location: Tallahassee Fl Age: 26
iTrader: 1 / 100% Ride: chevy s-10
Rep Power: 255 | 20-50 is way thick. I used cheapo oil for the first 500 break in miles or so. hen went to mobil-1, 10-30 full synth. Now that the motor isnt running as hot i swicthed to 5-w30. i'm using ngk BKR6E-11 plugs from advanced auto parts. Just ask for plugs for a gsr. TYpeR'a are BKR7's. that is all. Last edited by Taco15; 11-27-2006 at 09:03 PM. |
| | #10 | |
Rep Power: 49 | Quote:
Then after 500 mi or so I'll have my buddy(tuner) sit in the passenger seat with Crome and a wideband, and tune it exactly to my motors specs. (different senarios- highway, street, racing, etc) I guess I'll run 10w30. Thanks everybody. I guess I'll go with the NGK TR7's then. Sound good and gravy? Last edited by Andrew; 11-27-2006 at 09:37 PM. | |
| | #13 |
Rep Power: 7 | honestly for a good break-in with a fresh motor, this is my belief for the best outcome: upon first startup, run for about 5 minutes, then increase RPMS to about 3000 and let it sit there for another three or four minutes. shut it off, drain the oil. fill it back up with oil, and take it out and run it for a while. don't run it too hard. get yourself a decent basemap thats safe enough to go play around in. run it hard but not too hard. change the oil again and you should be good.
__________________ 1999 Accord EX - The Baller Ride / Beater Project Turbosaurus Rex in the works. www.skandalousinc.com for bags, body drops, boobs, and beer. |
| | #14 |
Rep Power: 49 | Oh... ok. Just for keepsakes, does anyone agree with spoolin@idle? sounds like a decent way to do it. Blanco, the only reason I don't take it straight to the dyno is 1. it won't be tuned(and I'm waiting to get tuned before I go), and 2. I'd rather not pay dyno fee's if it's the first run, and it blow-up or something. I can blow it up on the street for free, but I have to pay to do it and get a stupidly-cool graph showing it... =) I like the way spoolin's idea sounded. I'm very open minded, so if anyone wants to chime in..... |
| | #17 | ||
Rep Power: 49 | Abel- Quote:
How did you break in your engine? That could be why you have bad blowby problems!!! Edit. Don't want to make a triple post- Quote:
I guess that answers my oil question Last edited by Andrew; 11-28-2006 at 09:46 AM. | ||
| | #19 | ||
Rep Power: 255 | Quote:
I drove it for a while staying out of vtec due to the bigger cams. i did this with the Pw0 ecu from the old setup. That way it ran just a tad lean for more oil to seap in and let the rings sit. By the way i used carquest 10-w30 oil. Again i stayed out of vtec. okkk maybe once or twice did i turn it to 7k. Not very often since it got slower in vtec. Anyway,I let my mom drive it for another 500 miles and then i changed the oil to mobil1 synthetic. Ran it for another month until i went obd1 and had Eddie tune it. Once it was tuned i beat on it like there was no tommorow. Vtec ripped the tires and i loved it. Blowby is coming from the valve cover. The air intake is sucking it up. Its fine now since i put a baffle in between. Now i just have to figure out why my 2 day old plugs are white keep up the good work andrew
__________________ Quote:
| | #21 | |
Rep Power: 7 | Quote:
| | #23 |
Rep Power: 255 | actually the wideband says i'm right on. 14.5-9 and 13ish on the top end. I say that pretty good. back to topic. due tp work i cant get anything done. If you want to tackle the suspension swap i'm up for it as soon as i get my other crx back |
| fully built ls swap for sale(complete swap!!! 1500 | turbozcteg | Parts: For Sale/Trade/Wanted | 5 | 10-23-2006 01:17 PM |
| FS: LSVTEC !!!! Fully Built Portflow ITR head on redon | klubhed1 | Parts: For Sale/Trade/Wanted | 4 | 04-16-2006 06:19 PM |
| Fully Built Type R Motor (JUN, JDM, Toda, Skunk 2 | AllmotorCRX161 | Parts: For Sale/Trade/Wanted | 18 | 10-04-2003 05:31 PM |
| B18c5 Toda/soon Fully Built N/a | teamreckless916 | Parts: For Sale/Trade/Wanted | 0 | 01-24-2003 02:19 PM |
| Fully Built Civic W/ Ls/vtec | lsvtecvx | Parts: For Sale/Trade/Wanted | 0 | 01-02-2003 09:19 PM |
