| | LinkBack | Thread Tools |
| | #1 |
| Junior Member | I am rebuilding a gsr that is toast, cylinders cleaned up at .010, crank is shot though ,, what are my options as far as cranks go, can I use a ls , and what is the advantage or disadvantage of using different crank,,, I have stock eagle rods adn wisico pistons but if I have to get rid of the rods fro different lenght I will Thanks |
| | #2 |
| Admin with a big stick Join Date: Sep 2002 Location: Dallas / Fort Worth, TX Age: 32
iTrader: 0 / 0% Ride: 2003 S2000
Rep Power: 392 | You can use the LS crank. You'll have to get new main bearings (of course) that match up to the new specs of the crank in the block. Advantages: Longer stroke = more torque, more displacement Disadvantages: Longer stroke = worse rod/stroke ratio (not really), lower rev limit (not really) You do have to use different length rods with the LS crank because it's a longer stroke crankshaft in a block with the same deck height as before. |
| | #3 | |
| Junior Member | Quote:
What size rods will I need and what will the displacement be. thankis | |
| | #4 |
Rep Power: 392 | Use the LS rods. They should be 137.0mm (or 5.394in), and the displacement will be 1846cc. Just whip out a calculator next time and figure out your dispalcement- it's not hard. You could also calculate your rod size that same way.... since you're using a crank with 1.8mm more stroke, you need a rod that's 0.9mm shorter than the ones you already have- either that or a piston with the wrist pin moved up 0.9mm. |
