Gsr T
Closed Thread
Old 01-20-2003, 08:11 PM   #1
Rep Power: 15 roach009 is off the scale
i want to a least throw 10 psi boost without hurting my engine my how head has been rebuilt with perofrmance cams and gears and has pot and polished. do i go with the je pistons and rods for the rebuilt bottom block for the turbo i'm using probably a drag turbo kit
roach009 is offline
Old 01-20-2003, 09:03 PM   #2
Rep Power: 20 prawjEKt Cx will become famous soon enough
Send a message via AIM to prawjEKt Cx
get some low comp pistons (9.0:1) and some forged rods.... and put your stock cams back in... then you'll be in some good shape
prawjEKt Cx is offline
Old 01-21-2003, 01:52 AM   #3
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
LAST WARNING ROACH
you are NOT doing this again.
POST YOUR QUESTION ONCE. you do not need 2312312312 threads for the same fucking question.
http://www.hondaswap.com/forums/index.php?...t=ST&f=7&t=5022
I WILL re ban you if you keep this shit up.
locked. use your other thread for the same question.
pissedoffsol is offline
Closed Thread
