H22/h23 Hybrid
Old 06-08-2003, 08:39 AM   #1
Rep Power: 0 OZlude is off the scale
i was wondering if anyone had links to or has actually performed the h22/23 hybrid conversion??
what is actually invovlved with putting the vtec head to non vtec block??
and is the end result as good as the stock h22 or does it have a better or worse output
thanks for any help
OZlude is offline   Reply With Quote
Old 06-12-2003, 11:55 PM   #2
Rep Power: 16 XZILER8 is off the scale
Send a message via AIM to XZILER8
Check it out......
click here
I've searched high and low for this information and finally found it. It's the only article i've been able to find, so I'm not totally sure how reliable the information is. I've been interested in this for quite some time, but given the lack of information, it must not be a very popular thing to do. That could be good, or it could be bad....I'm not really sure but I'm going to wait until I can get more backing on the information before I attempt it.
Now accepting applications for "Female Friend with Benefits "
XZILER8 is offline   Reply With Quote
Old 06-13-2003, 09:12 AM   #3
WRX Sellout
Ride:  2002 WRB Impreza WRX
Rep Power: 99 dohcvtec_accord is an unknown quantity at this point
Good find! I think I'll pin this up....
This space left intentionally blank.
Old 06-15-2003, 02:37 PM   #4
Rep Power: 14 accordh23 is off the scale
Puting a h22 head on the h23 block is a very good thing but also kinda bad i was going to do i have the h22 head siting here at the house but yhe only thing holding me bacl is that you will not bw able to drive the car for a long distance for some reason that what all the shop around here have told me
accordh23 is offline   Reply With Quote
Old 06-15-2003, 03:02 PM   #5
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Take your car to Intercrew along with $2500... they'll do it for you, and do it the right way. $2500 installed and running with all parts included isn't bad at all, considering how much those heads run.
Old 06-15-2003, 11:34 PM   #6
WRX Sellout
This is the equivalent of saying "My brother's girlfriend's cousin said that it might be a bad thing to do....". Can your shop explain that claim at all?
And Calesta, you're right, that's a damn good deal for the hybrid.
Old 06-16-2003, 02:46 AM   #7
Calesta's Avatar
Ride:  2003 S2000
Old 06-18-2003, 06:13 PM   #8
Ride:  DC2 ITR and DC4 LS
Rep Power: 19 Gen2Teg is off the scale
Send a message via AIM to Gen2Teg Send a message via Yahoo to Gen2Teg
anybody know what the CR is for the hybrid? i know it can be different but i wanna know some stock figures.
Gen2Teg is offline   Reply With Quote
Old 06-28-2003, 12:07 AM   #9
Rep Power: 14 racerx h23 is off the scale
You'd definatly want to get the h22 piston to bump compression. Also, the oil squirts in the block for better reliability.
$2500 is cheap! I haven't found anyone besides the dealership that will part out an h22.
Honda-tech has a sticky for the h23vtec you should check out if you're interested.
racerx h23 is offline   Reply With Quote
Old 09-01-2003, 05:46 PM   #10
Rep Power: 15 KyleCrews is off the scale
A friend of mine blew his motor on his 95 lude about a month ago and swapped in a h22 type S. The only thing wrong with the motor is he broke the crank and one of the rods and he said he would sell it to me for a couple hundred bucks. Since everyone has been talking about how the h22 has a better cooling system, then instead of swapping out the head and other parts to build my h23vtec, couldn't i just swap the crank, rods, and pistons out for h23 ones. I want the h23 pistons for the lower cr because i plan to boost. This would basicly be the same as swapping the head and i'd still get the 2.3 liters of displacement. How hard wouild this be to do and is that all i would need to swap out. I'm getting the ecu from him too. Thanks.
I took part in a Survey of 100 Men, What do men like best about a blow job
99% answered The 10 miniutes of silence
KyleCrews is offline   Reply With Quote
Old 10-13-2003, 07:27 AM   #11
Rep Power: 16 DesertNightEagle is on a distinguished road
Send a message via AIM to DesertNightEagle
kyle crew,
that would not work. the bore of a h23 is slightly larger than a h22, which i figure you are trying to put the pistons and rods in. and the thing with most of these honda blocks is the boring job. most machine shops do not want to touch them unless you agree to go with iron sleeves, that there is about $400, plus they'll get you to buy a rebuild kit which is little over $500. and if you are lazy like me it cost $350 for them to balance and reassemble your engine. so its not really worth putting those pistons in, especially since you can get dished low compression pistons for a h22. or if you want a large displacement you can buy 2.6L h22 shortblock from rddyno.com for about 3.5k
'92 Prelude Si
H22/23 Hybrid
Port & Polished Head
Crower Stage 1 Cams
AEM Tru-Time Cam Gears
AEM Power Pulleys
AEM Fuel Rail
Hondata ECU w/ P300
RC 55lb Injectors
70mm STR Throttlebody
Golden Eagle Intake Manifold
T3/T4 Turbo
Spearco Intercooler
Tuning/turbo/Labor by JE Imports
DesertNightEagle is offline   Reply With Quote
Old 10-13-2003, 11:00 AM   #12
WRX Sellout
Helm's lists them as being the same.
Old 10-14-2003, 12:08 AM   #13
i believe my machinest said the bore for h23 was slightly larger, like .020 larger than the h22. i asked him this cuz i wanted h22 pistons for higher compression for an all motor engine
'92 Prelude Si
H22/23 Hybrid
Crower Stage 1 Cams
AEM Power Pulleys
AEM Fuel Rail
Hondata ECU w/ P300
RC 55lb Injectors
T3/T4 Turbo
Spearco Intercooler
Old 10-14-2003, 11:03 AM   #14
WRX Sellout
Well, then the H23 must have been overbored at some point in its life (which I'd believe since it's .020 over). The H22 and H23 have the same bore, they differ in stroke.
Old 10-26-2003, 10:56 PM   #15
Rep Power: 13 h22poweredgsr is off the scale
The H23 and H23 have the same bore
that makes sense....
h22poweredgsr is offline   Reply With Quote
Old 01-09-2004, 08:02 PM   #16
Rep Power: 15 92civicvx is off the scale
Send a message via AIM to 92civicvx
i have heard that if you want the displacement of a h23 in an h22 you can add either the h23 rods and crank or the f22 rods and crank and make it a 2300cc if i am wrong let me know i just heard that you coulld do that
92civicvx is offline   Reply With Quote
Old 01-17-2004, 04:13 PM   #17
Rep Power: 0 Broken is off the scale
Yeah, I found an article while searching for doing this. I have a 97 Lude and was planning on swapping in H23 crank with stronger H22 rods and JDM Type-S pistons. Found all the parts but whant to make sure nothing bad will happen, or something not forseen. Is this an easy bolt in, well easy for a good mechanic anyway, or would I be better just keeping my crank, better rods, pistons, and cams???? I already have the AEM fuel rail/pressure regulator, AEM CAI, Jacob Electronics Ign, etc...
LMK
P.S. I love this forum!!!
Broken is offline   Reply With Quote
Old 04-13-2004, 02:07 AM   #18
Rep Power: 12 Elo'rin is off the scale
Post
Hey,
I'm new to this site. I hope this is what I want. I have the h23 for my 92' prelude.
The engine is stripped. I paid $500 for the whole car. I want to vtec it with an h22 head. The problem is I don't know how or where to start. It has some scratches. I have to bore the engine. What should I do?
Thanks,
Elo'rin
Elo'rin is offline   Reply With Quote
Old 05-08-2004, 01:40 AM   #19
Rep Power: 14 Import Builders is off the scale
I will do a full write up on my H23/VTEC engine/Car when its done in a few weeks. Or less.
I will clock how many G's it does the turns at (I have a G-Sensor).
I will clock it 0-60 MPH
I will clock it 1/4 mile with street tires as it sits and drives.
And I will detail what parts and how much it all costs.
I got a good tranny with a quaife with 225/50R15 of the best tires money can buy, so I imagine it should be quick.
Jeff
[url=http://www.importbuilders.com[/URL]
<a href=\'http://www.importreview.com\' target=\'_blank\'>Proof our stuff works</a>
<a href=\'http://www.ibspec.com\' target=\'_blank\'>E-Commerce</a>
And now...the UNDISPUTED King of Value for Turbo's
<a href=\'http://www.importbuilders.com/turbo.html\' target=\'_blank\'>Turbo's, Intercoolers, Wastegate, Manifolds</a>
Piston/Rod Engine questions? Ask away! I am here to help!
Import Builders is offline   Reply With Quote
Old 05-10-2004, 12:35 AM   #20
Rep Power: 12 jdmvteccrx is off the scale
everyone should read jeffs article after he finishes because he doesn't lie.... and most other people do, to make them self look not as dumb.
some stupid ricer:
"i just bolted a dohc vtec head on my civic d16"
jdmvteccrx is offline   Reply With Quote
Old 05-10-2004, 03:22 AM   #21
I don't know who you are, but yes, I try not to lie at all, and if I see that I said something thats wrong, I like to fess up to it right away and change it.
I will do the most detailed, rediculous article for you guys. I have alot more interest in it since its my own car.
Also, what will be fun, is I will release a "Video" of the G-Sensor datalogging accelleration, skid pad, etc.
So we can compare the cornering to a Ferrari Enzo or something. I wonder if I can hit 1.1 G's in the Turns. My friends track car hits 1.3 G's on the turns BARELY. Of course, its a full race car.
Jeff
Old 04-29-2005, 11:32 AM   #22
Rep Power: 0 vangsta is off the scale
ok, does anyone if an h23 crank will fit to a h22a block and head, and is it good or bad
vangsta is offline   Reply With Quote
Old 06-22-2005, 01:31 AM   #23
Rep Power: 0 22sleeper is off the scale
hey im new here but i would just like to suggest that the best way to do this is to find someone that has already done it and ask all the ??? you can. ive only seen one and it was owned by a shop in miami. it was a 23 block with a 22 head turbo in a gutted hatch. never seen it run but im sure the parashoot in the back wasnt put there for looks. anyways the shops name is RICKY'S. however i do not recomend buying anything from him unless your willing to give up your first born. but he should provide you some kind of info.
22sleeper is offline   Reply With Quote
Old 10-11-2005, 10:39 PM   #24
Rep Power: 9 purestreetracer is off the scale
hey whats up. i saw all the posts and curiousity about the H22/H23 ls vtec H style questions. well im doing a h22/h23 right now its done just got to pick up the bottom end and put my motor back together. we'll se what i dyno and i will post it here. just for info. on the H motors the bores are the same and u can bore em i think a max of 25 over. 30 over and u run out of the coating thats on the cylinder walls of the block. what i did was bore mine out 25 over running h23 rods cuz the longer stroke, H23 crank(micro polished), type s oversized H22 pistons with floating wrist pins and the rods have to be prept to fit these pistons. i dynoed 205 hp at 7400rpm and 160lbs. of torque at 5900 with the 22 before with stock head stock h22 block stock cams with type s pistons and the bolt ons i mentioned tuned by sinister in morgan hill,ca. we'll see what no.s i put down now. thats all i have done to the block the head now has a stage 3 port with upgraded Valves,springs, etc. with stock ported intake manifold. no cams stock. emm intake, header(kamikaze4-1)clutch,flywheel,pulley,skunk2 sohc ecu chip, i think p28. and vtec cont. with fuel reg. as everything else stock. im hope i put out at least 210hp with 175 or so torque. but the thing is when you bore out this motor you have to break it in not sure how many miles till break in but i will find out tommorow. then i will dyno , i guess i have to keep it under 3000rpms for a while. that sucks but i will post the hp no.s soon.
IF you need parts for H series i have some for sale.tranny/ cheap too. and i have a JUN chip p13. shit like that. to many parts for my H22/23.
purestreetracer is offline   Reply With Quote
Old 10-11-2005, 11:08 PM   #25
<div class='quotetop'>QUOTE(vangsta @ Apr 29 2005, 08:32 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
yes everything is pretty much universal in H series motors. bore same. h23 has a longer stroke. if u use a the h23 crank your gonna have to use the H23 rods cuz of the different stoke length other wise u will drop compression if u use the 22 ones. or have custom rods made or upgraded h23 rods so that the lengths are the same as far as the piston it doesnt matter same bore size, unless bored out but then everyone should know that. then u get into custom shit.
Update H22/H23 DesertNightEagle HYBRID -> BA-BB /CA-CD 63 08-03-2005 12:22 AM
H22/H23 franken swap sleeper485 Engine Building 6 08-04-2004 09:31 PM
research paper, what do you think? 90 accord Members' Lounge 9 06-23-2004 12:11 AM
Hybrid Revolution Phone Number BryanPendleton Members' Lounge 1 01-06-2004 02:41 PM
B16/b20 Hybrid simonc Engine Building 3 05-21-2003 04:54 AM
