H22A Civic Question
Old 12-25-2002, 08:57 PM   #1
Rep Power: 0 99CX is off the scale
I have an 99CX and I am in the working of putting an H22A in it, I would like to run a 50-75 shot, my question is will my fuel be ok??? I plan on swapping the fuel pump, but will everything else be sufficient?? Will it be able to supply enough fuel to use nitrous and not run lean?
Also, will I need a fuel injector resistor pack in my swap???
99CX is offline   Reply With Quote
Old 12-25-2002, 09:28 PM   #2
Rep Power: 28 paragus is off the scale
yes you should be allright fuel wise.. and yes you need the resistor pack, unless you feel like frying your ecu
Cankles are sexy.
Pep Boys - "We're rice people"
Asthma is sexy.
paragus is offline   Reply With Quote
Old 12-25-2002, 11:07 PM   #3
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
your fuel will be fine...
97+ prelude injectors are saturated, as are the 99CX.
the 92-96 'lude injectors are peak and hold, and then the resistor will need to be used.
Old 12-26-2002, 03:52 AM   #4
k, where can I get a resistor pack?? what exactly is it??? and what does it hook up too?
Old 12-26-2002, 06:05 AM   #5
RETIRED
4th gen civic... it changes the impedence of the injecotrs
Final help installing JDM h22a in civic hatch AEIperformance.com 92egH22 HYBRID -> EG-EK / DC 34 10-01-2008 02:07 AM
h22a transmission question???? driver1 General Tech and Maintenance 4 09-11-2005 08:32 PM
1995 Civic EX Swap question Sikriel HYBRID -> EG-EK / DC 44 11-05-2004 12:55 PM
96 Honda Civic Ex With H22a h22aCivicEX HYBRID -> EG-EK / DC 8 03-31-2003 03:29 PM
Civic Gauge Cluster Question... thebeast3416 ECU's, Electronics, and Tuning 7 01-21-2003 10:12 PM
