#3 | |
^^ Likes Bewbies
Ride: Rex, Yamaha Virago, CB900F Supersport
There really isn't such a thing as "easy" power. Bolt-ons can get you closer, though.
#8 | ||
Ride: 1992 H22A Accord EX
and lightweight clutch, flywheel, and wheels.
#10 |
Brutal Moderator
Ride: 97 Integra LS Coupe
Crank horsepower doesn't equal wheel horsepower. At the wheels, a stock H22 is going to put down around 150-160 horses...
Please tell me how any of those things add horsepower... __________________
#11 |
Green on the scene.
Ride: Fuckin Prelude Si 2.1l 1990
some people consider freeing power up, adds horsepower.
if thats the case, strip the interior. |
#12 | ||
^^ Likes Bewbies
If your car has 150hp and you take 300lbs of stuff out of the car, it still only has 150hp. __________________
#13 | |
Brutal Moderator
I call those people "idiots"...
![]() __________________
#16 | |
^^ Likes Bewbies
I'm aware of that. But I was pointing out the fact that it still doesn't add power. If you send the same car down the track two different times--one with interior, one without--the numbers aren't going to be spectacular enough to make someone want to gut their car.
#17 | |
Been down so long...
Ride: '98 Civic w/ Turbo H22A
#19 |
Build up the bottom block, (darton M.I.D sleeeves it), stroker kit (better displacement), Stage 2 street cam/ gears, valve srpings and retainers, Larger exhaust system 2.5-3" piping.
Vtec should scream like no other. Someone correct me if i'm wrong, this should make somewhere in the 230-240 neighborhood. |
#20 |
So it sounds like the H22A drivetrain eats up 25% of the power. So you would need to make like 260HP to the crank, to get 200 to the wheels. damn, our H22s SUCK! I thought FWD drivetrains were supposed to be more sufficient than RWDs? Also I thought the shorter gears of the H22A tranny (the m4....whatever) would make it more efficient, too.....I guess not.
#21 | |
yep....mmhhm.......yep...
Ride: 92 PRELUDE SI
i had i/e/h and hondata ecu with a good tune i made about 176whp or so. i bossted built everything up now i got 400+
Hugh.......I like money....... "idiocracey" Quote:
| Jdm H22a Or Jdm H22a Type-s | B|ade | HYBRID -> BA-BB /CA-CD | 14 | 02-16-2009 01:56 PM |
| OBD2 h22a type S in my OBD1 H22a hatch | Zarboz | ECU's, Electronics, and Tuning | 2 | 11-22-2008 11:27 PM |
| Honda : Civic H22A Turbo Clean Civic Hatchback with H22A-TURBO - No Reserve | RSS-Bot | Auctions | 0 | 12-04-2007 05:23 PM |
| Honda : Civic H22A Turbo Clean Civic Hatchback with H22A-TURBO - No Reserve | RSS-Bot | Auctions | 0 | 11-27-2007 12:33 PM |
| h23a to jspec h22a or us h22a | pitvpr | HYBRID -> BA-BB /CA-CD | 2 | 10-22-2004 08:42 PM |
