civicious said:What are you talking about? Have you even read any of my posts? Where have I said to use LS head bolts on an ls/vtev swap?
you said always use the head bolts that match the block.
WHY would you use the studs that match the head? The major difference is in the BLOCK, not the head...the BLOCK is what they're screwing into, and the studs have to be long enough to thread into the block...
did you not?
Ive been building motors since before you where in middle school
19? give me a break. and you wana tell me how to build somthing.
