Help changing Headgasket On a B16A
Old 12-18-2006, 02:21 AM   #1
Rep Power: 0 Civic-8442- is on a distinguished road
Question Help changing Headgasket On a B16A
okay ive tried hond atech and they just laugh!, so now ill try here too see how it is with tech ?'s
ive got a B16a thats out of my car right now and i want too change the headgasket,timing Belt,water pump on it before i put it in my car!!?
'I need help with changing everything out especially the headgasket ive seen it done but i wanna make sure i get it all RIGHT the first time and not risk it! same goes for the timing Belt.
also on the headgasket!, should i just buy a oem one again or step it up? and raising my compression is good for ????/, i wanna go all motor! head is fully built already so yeah.....
Civic-8442- is offline   Reply With Quote
Old 12-18-2006, 01:43 PM   #2
Slammed EJ2 y0
Ride:  SlammeD 95 civic
Rep Power: 6 laoboisosilly is on a distinguished road
Send a message via AIM to laoboisosilly
to change the head gasket you need to remove the head,to do so remove the the timing belt, valve cover, cams, and all the rocker arms and cam caps and yada yada, there will be 10 bolts when you look inside there, remove them in this order
3 5 9 7 1
2 6 10 8 4
to remove the water pump, remove the water passage, and then remove the bolts from around the water pump and pull it off, i duno if all this is 100% accurate or not so dont rely on it but as far as headgasket goes, get an oem honda one
laoboisosilly is offline   Reply With Quote
Old 12-19-2006, 08:40 AM   #3
Ride:  '91 Civic hatch DX
Rep Power: 9 Exodus is off the scale
Send a message via ICQ to Exodus Send a message via AIM to Exodus Send a message via MSN to Exodus Send a message via Yahoo to Exodus
Hybrid Honda
Look for a manual there.
Exodus is offline   Reply With Quote
fs ls b18b b16a DA integra civic cx parts lshatchcx18 Parts: For Sale/Trade/Wanted 11 03-17-2005 05:49 PM
fs: b16a, b18b parts lshatchcx18 Parts: For Sale/Trade/Wanted 26 02-27-2005 06:09 AM
1st gen b16a into obd1 del sol sol2nr HYBRID -> EG-EK / DC 5 04-20-2004 10:08 AM
B16A Variants pissedoffsol Swap Articles 0 01-12-2004 02:31 AM
B16A SiR 1 into a 5th gen chassis pissedoffsol Swap Articles 0 01-12-2004 02:12 AM
