Help determining which bearings to buy.
Old 11-28-2008, 02:26 PM   #1
Conan The Hondarian
wikedeye's Avatar
Ride:  1993 Honda Civic Dx Coupe
wikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to behold
Send a message via AIM to wikedeye
Default Help determining which bearings to buy.
I need some help figuring out which bearings I need. I know how to match the letters on the block and the numbers on the crank, but I cant read some of the numbers. Is there another way to tell, or can I somehow make the numbers more visible by lightly sanding or cleaning with some sort of solvent. I dont want to mess up the crank by sanding, or using something that would somehow affect the coating on the journals. I have the bearings that were originally there and they are color coded, but I think this engine has been rebuilt at some point because one of the rod bearing caps was facing the opposite direction from the other three, so I dont want to trust that they are the right sizes. Any help or recommendations would be greatly appreciated. Here is a picture of the crank, it may help you understand what I am talking about. The fourth nob over has a 1 and the sixth has a 2, but that is all I can make out. And the crank is not being stored on it side like in the picture, it is standing on its end.
Originally Posted by 99sidude View Post
yes silicone lubricant worked great on my shaft. highly recommend.
XBL: Wikedeye
wikedeye is offline   Reply With Quote
Old 11-28-2008, 03:55 PM   #2
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Luis998 has a reputation beyond repute
Luis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond repute
Hey Conan. I don't have your answer but I do have a place that will. Blanco has reccommended them through and through. They should be able to help you with your bearing needs. Majestic Honda - The Internet's #1 Honda Automotive Parts Store Magestic Honda for the win. SWOOSH!!! Best of luck my friend.
Luis998 is offline   Reply With Quote
Old 11-29-2008, 07:21 AM   #3
Conan The Hondarian
wikedeye's Avatar
SO basically I just buy the green as a generic guide. Then plastigauge to see how much clearance there really is. Then buy new bearings based on the measurements correct. I am going to try the alcohol first and then go from there.
I just checked out Majestic Luis and their prices are really good. I have been looking at manchester honda, but majestic is lower by about a dollar a bearing which is cool.
Old 11-30-2008, 08:33 AM   #4
Conan The Hondarian
wikedeye's Avatar
Thanx a lot. I am going to try and clean it first, but if that doesnt work then you gave me more then enough info to get it worked out.
Old 11-30-2008, 09:37 AM   #5
Conan The Hondarian
wikedeye's Avatar
Ok, thanx again.
Old 11-30-2008, 07:49 PM   #6
FI FTW.
Matts96HB's Avatar
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Originally Posted by Blanco View Post
Anytime.
Another helpful tip. Use a laminated card, like a video store membership card, to scrape the Plastigage off of the test bearing and journals. Be gentle so you don't scrape the coating off of the bearing. Do two rods with one bearing half and then flip them over so you can use the other half for the other two rods.
The laminated card works very well. It took me awhile to figure out what to use, then I was looking in my wallet and saw my Safeway club card
Matts96HB is offline   Reply With Quote
Old 11-30-2008, 08:00 PM   #7
Regular Member w/ Cheese
YBLEGAL's Avatar
Ride:  2000 EJ8 w/ SiR-II
YBLEGAL has a brilliant future
myspace
Plastic cards are a great way to take apart cell phones too (any small or sensitive things for that matter).
Wonderful information by everyone. I have learned!
Old 12-01-2008, 04:47 PM   #8
Conan The Hondarian
wikedeye's Avatar
Here are some pics of the crank after I cleaned the numbers with alcohol. It worked really well, which is good because I didnt want to have to go through the trouble of measuring everything. Thanx again Blanco.
ACL bearings hmtcrxsir Engine Building 48 07-01-2005 03:47 AM
bearings Dark91zc HYBRID -> EP / DC5 0 06-20-2005 12:25 AM
bad bearings? 97CTR Engine Building 2 06-16-2004 01:13 PM
where to buy main bearings and rod bearings KFBhonda Engine Building 13 01-13-2004 11:13 AM
Rod Bearings & Main Bearings Slimtadder Engine Building 11 01-08-2003 04:19 AM
