help! final drive type r ls turbo setup
Old 07-28-2006, 08:27 PM   #1
Rep Power: 0 NEXTEL_31 is on a distinguished road
Default help! final drive type r ls turbo setup
hi i have a b16 sleeved to 84mm for a turbo setup and i bought the LS S80 HYDRO TRANNY. i also bought the type r differential without the ring gear. i wnat to know if i buy the type r 4.7 final drive which includes: ring gear, coutershaft, needle bearing, first gear(but don't kbow if use since its short), and distance collar. will this go into my ls tranny. please let me know and if would be a good setup. thanks cubano4v16@yahoo.com
NEXTEL_31 is offline   Reply With Quote
Old 07-28-2006, 08:33 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 288 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
If you get the right gear set you should be fine. I would just run the 4.4 final drive... or better yet, sell the LS transmission and your differential, then get a JDM GSR LSD transmission or a USDM GSR with a Quaife in it.
Old 07-28-2006, 08:37 PM   #3
Yeah But I Want Long Gears And I Aready Have This Is Not Going To Be The Same Setup As The Jdm Gsr By Doing This
Old 07-29-2006, 10:21 AM   #4
Calesta's Avatar
Ride:  2003 S2000
Why do you want the really long gears?
Old 07-29-2006, 07:07 PM   #5
for turbo setup because if i buy the gsr its shorter than ls thas why
Old 07-29-2006, 10:01 PM   #6
Calesta's Avatar
Ride:  2003 S2000
Long gears aren't necessarily good for a turbo setup.
Final Drive Question templevy General Tech and Maintenance 6 09-15-2004 01:57 PM
what turbo to go with my b18c5 setup civicrturbo Forced Induction 11 11-23-2003 10:52 PM
Type R Or Ls Turbo? skylineboy HYBRID -> EG-EK / DC 16 02-24-2003 09:24 PM
B18c5 In 88 Crxdx Will There Be Room 4 Turbo?>? T4 88crxdx HYBRID -> EG-EK / DC 13 02-04-2003 05:03 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
