can you say 260 whp N/A??
i am currently doing a build on my gsr block. basically all i need to know is that if i take my gsr block and put an ls crankshaft on it i have a lager stroke do i need shorter rods or can i use my gsr rods. the only thing i am worried about is that since the gsr crank is smaller and ls is larger and the gsr crank makes the pistons flush with the deck if i use an ls crank and my gsr rods in my gsr block and put itr pistons in it will they come out the top of the block, do i need custom shorter rods? i dont want my piston to hit the head, or will this be fine and i can put it together no worries..
buy my motor!!! check out link. http://hondaswap.com/parts-sale-trad...ression-93212/ |
Admin with a big stick
Ride: 2003 S2000
If you use the LS crank, use the LS rods. Your compression with the same pistons will be slightly higher with the LS crank/rods than with the GSR crank/rods.
the only reason im wondering about my gsr rods is because with itr pistons and the ls crank i dont want anything higher then a 12:1 cr but your saying if i stuck with ls rods and crank and itr pistons i will get a higher cr then i would with ls crank gsr rods itr pistons?
my main worrie is i dont want the piston to extend past the deck of the block __________________
im using the b18c1 block
#5 |
Ride: 2003 S2000
Yes. The B18C1 block is the same height as the B18A/B blocks.... same height as the B20B/Z blocks too. I used a B18B crank in my B18C block and everything was fine- you just have to use the shorter B18B rods to match. Lots of people do it.
#6 |
so i should not use the gsr rods is basically what you are saying
#7 |
Ride: 2003 S2000
No. Do NOT use the GSR rods with the LS crank.
#8 |
what could go wrong with the rods or is it just the compression wont be as high. i have a friend also thats trying to do it will the rods not work? sorry for all the questions he keeps bothing me about it
#9 |
Ride: 2003 S2000
The compression will be higher with the GSR rods, and depending on the pistons, they might stick out the top of the bore and slam into the top of the combustion chamber. The GSR rod is .9mm longer than the LS rod.
#10 |
im going with a set of itr pistons at .20 overbore so i can shave the block a bit, has lots of miles, that was my basic question, if i use gsr rods with that crank will they peak out the block? if so ls rods will work correct?
#11 |
Ride: 2003 S2000
Yup. I've said it twice already. LS rods with LS crank, GSR rods with GSR crank.
#13 |
thanks. only reason i was asking its because i heard ls rods were weak, ill just get them bead blasted and balanced along with the crank
#14 | |
Blah blah blah....
LS rods are fine, just get ARP rod bolts for them.
#15 |
Greenhorn
Ride: 98 integra type-R
i have a jdm b18c, it spun the rod berings,so id like to put in aftermarket crank&rods,crower has the stroker kits but there 2 grand. id like to go a lil cheaper, peice parts togather.could i drop in ls rods and crank? or gsr? or type R? or even stock jdm type r? i dont know what way 2 start. the forum waz helpfull but 1 guy said the b18c and b16b blocks are about .55mm taller then the b18a/b or b20b/z blocks, but are they the same hight as the b18c1 and or b18c5? thanks//
| Benson sleeved B18B block, CP pistons, Crower rods, brand new, $2 | turbolscivic94 | Parts: For Sale/Trade/Wanted | 5 | 03-13-2009 02:03 PM |
| WTB: GSR Rods and possibly pistons! | som1dies | Parts: For Sale/Trade/Wanted | 3 | 12-15-2006 11:03 PM |
| ls/vtec werd | KWJaY | Engine Building | 11 | 09-10-2003 05:39 PM |
