This is a discussion on help! removing connecting rod in the Engine Building forum
ok, I've removed all of the pistons and rods from my b18c1. I just need someone to explain how the heck Honda put their rods on, because its not a pinch washer and I need the piston detached from the rod.
http://www.flickr.com/photos/36070176@N08/3328070806/
http://www.flickr.com/photos/36070176@N08/3327236407/
http://www.flickr.com/photos/36070176@N08/3327236445/...
| | #1 |
| ok, I've removed all of the pistons and rods from my b18c1. I just need someone to explain how the heck Honda put their rods on, because its not a pinch washer and I need the piston detached from the rod. http://www.flickr.com/photos/36070176@N08/3328070806/ http://www.flickr.com/photos/36070176@N08/3327236407/ http://www.flickr.com/photos/36070176@N08/3327236445/ |
| | #2 |
| the piston pins are pressed into the rod - you need to have them pressed out |
| | #3 |
| | #4 |
| Sometimes you can take a small propane torch and heat the small end. This will cause the opening to open up a little more and allow the wrist pin to come out. Just keep the heat off the piston. |
| | #5 |
| I'm pretty sure it'll take more heat than that. I bought a set of pistons where some guy obviously tried to do that(rods had burn marks all over the PE ends). |
| | #6 |
| take them to a machine shop. |
| | #7 |
Similar Threads | ||||
| help! connecting rod trouble | dc forever guy | HYBRID -> EG-EK / DC | 5 | 03-25-2009 06:07 PM |
| h23 connecting rods | nootrac22 | Prelude | 10 | 05-19-2008 10:17 PM |
| Connecting pins will not fit? | Abrasintegra | Engine Building | 7 | 03-11-2006 12:18 PM |
| connecting rod bearing | m2slsvtec671 | Engine Building | 0 | 04-27-2004 03:27 AM |
| ZC connecting rods | 22crazy | Engine Building | 0 | 08-05-2003 05:58 PM |
