Help in Swapping engine parts
Old 01-31-2007, 02:35 PM   #1
gpeterso is on a distinguished road
Default Help in Swapping engine parts
I am building an engine for an off-road car that limits its cc's to 1750. My idea is to use the B18C motor and swap the crank and rods from the b16 del sol motor, does anybody know if that will work? or is there a better bang for the buck to get my cc's and still retain the highest aspirated HP I can. Thanks
gpeterso is offline   Reply With Quote
Old 01-31-2007, 02:39 PM   #2
Führer Mod
eg6sir's Avatar
Ride:  Le Car
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
just drop a obd1 JDM b16 in there..
eg6sir is offline   Reply With Quote
Old 01-31-2007, 02:42 PM   #3
Default Crank and Rod swap.
Do you mean the whole motor? or the crank and rods from the JDM b16? If whole motor does it have the same HP and Tork as the B18C?
Old 02-01-2007, 10:41 AM   #4
Class 10 Baja car
Old 02-01-2007, 04:57 PM   #5
What small engine does have torque??? These cars are gear to go no more than 110MPH with a 5 speed tranny so torque is important but not the first critical factor. Everybody else in the class has the same issue so I am not too concerned. Does anybody know if I can use the B16 gen2 motor and drop in crank and rods from the b18a motor to get the cc's up to where I need it, 1700-1750 or so??
Old 02-01-2007, 06:45 PM   #6
Dismember
Ride:  Whatever i can get behind the wheel of
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
I'm glad we have Blanco here to preach against the evils of the B series. /sarcasm
The B16/B18 would be an excellent choice, and I'm fairly certain the internals are interchangeable. You'll have to compare the bore/stroke from both the B16 and B18 to figure out if you'll be under 1750cc but I would guess that a hybrid between 1600 and 1800 would put you close. Check the red print in my sig before you take my advice.
klyph is offline   Reply With Quote
Old 02-02-2007, 12:26 PM   #7
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
lsvtec is on a distinguished road
Holy misinformation Batman! B16 internals can fit in the B18 block, (though compression would be too low to run well) but not the other way around. If you used anything but a B16A block the B18A internals would put a piston through the head.
The closest I can come using only Honda parts is B18A block with a 1mm overbore and a B17A crank gives you 1,719 cc. This setup with require custom rods/pistons because nothing that Honda makes will give you compression ratio higher than about 9.5:1.
lsvtec is offline   Reply With Quote
Old 02-02-2007, 07:28 PM   #8
Dismember
How is he going to get a D series to 1700-1750cc? I think destroking a B18 is his only option as far as Honda engines go. Unless he had a custom crank made for the D, but that's more $$$ than it's worth.
And you're always braggin about how you make more torque than a stock B series, yet your D is FAR from stock. You could take a stock B series, put a heavier flywheel on it, and make more torque than your D all day long. B series are made for high end power (at which they will also kick the shit out of your D) torque is almost meaningless when talking about Honda engines. None of them have any.
Go to work, Act normal, Believe the News, Save for your old age, Obey the Law
Repeat after Me: I am Free
Swapping In An F20b Engine jasminegab HYBRID -> BA-BB /CA-CD 13 05-28-2009 02:58 PM
AE86......... Airjockie Vehicles: For Sale/Trade/Wanted 19 01-18-2005 12:14 PM
Engine Removal Guide pissedoffsol Swap Articles 0 01-12-2004 01:19 AM
d16y8 engine and other parts for sale asagage HYBRID -> EG-EK / DC 0 10-21-2003 09:21 AM
swapping a gsr engine into a 98 civic ex 98civic EX HYBRID -> EG-EK / DC 1 10-12-2003 05:04 PM
