High Compression Build vs. Low Compression Build? Trying to clear something up..
Old 08-22-2008, 10:02 AM   #1
Eh?
oneofakinduserid's Avatar
Ride:  93 Civic DX and an 89 CRX
Rep Power: 33 oneofakinduserid has much to be proud ofoneofakinduserid has much to be proud ofoneofakinduserid has much to be proud ofoneofakinduserid has much to be proud ofoneofakinduserid has much to be proud ofoneofakinduserid has much to be proud ofoneofakinduserid has much to be proud ofoneofakinduserid has much to be proud of
Send a message via MSN to oneofakinduserid Send a message via Yahoo to oneofakinduserid myspace
Default High Compression Build vs. Low Compression Build? Trying to clear something up..
I've been trying to read up on the different ways to build an engine, and why one would go with each particular tactic (if any of that makes sense lol)
so what I think I've learned (and this thread is really just to make sure I've got it right), is that if you're planning on putting a turbo on an engine, you would want to build it with lower compression, right? Is this because of the air that's being forced into the engine, you don't need that much pressure?
And if you're going all-motor, you'll strive for higher compression to make up for the lesser induction? Do I have this right or am I mixed up? There aren't a lot of articles that really explain the difference between the two.
I'm learning slowly, a year ago the only thing I knew about fuel injected engines was "suck squish bang blow" lol.. I try to read about it as much as I can before I bother you guys with questions. Thanks for any responses =)
Originally posted by: B
indeed, done.
i don't have time for this nonsense.
i'll ban your whole state.
ask arizona. i did it before. i'll do it again
oneofakinduserid is offline   Reply With Quote
Old 08-22-2008, 10:07 AM   #2
^^ Likes Bewbies
George777's Avatar
Ride:  Rex, Yamaha Virago, CB900F Supersport
Rep Power: 119 George777 has a reputation beyond reputeGeorge777 has a reputation beyond repute
George777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond repute
You are correct with the HC for N/A and LC for boost. As for the logic (airflow) behind that, I don't know how valid that is. I'm sure someone will let you know the exact reasons.
Research is your friend. Now if only half the people would do their own research before asking stuff, things would be better.
Originally Posted by Blanco View Post
Eat shit and fucking die you ignorant redneck.
Originally Posted by B16RacerN2NR View Post
I don't know how to do plastic surgery but I love titties, you don't see me trying to go around giving breast implants do you?
Originally Posted by phyregod View Post
Yup, Its sex on wheels. Violent, vigorous sex. With a super model. Scratch that, super model twins.
George777 is offline   Reply With Quote
Old 08-22-2008, 11:00 AM   #3
Regular Member w/ Cheese
YBLEGAL's Avatar
Ride:  2000 EJ8 w/ SiR-II
myspace
You should read our article on Static vs. Effective Compression. That will give you an idea.
Think of it this way. A turbo is literally a compressor. And 1 atmosphere is literal compressive pressure. Natural aspiration builds the motor for a constant 1 atmosphere of pressure, and effective compression does not change, and the way air fuel ratios and heat work, there's an upper limit on compression. Forced induction builds the motor for a variable input of pressure, thus making the effective compression that much greater than the static compression which is at 1 atmosphere. Increases in boost, which is literal compression (just like an air compressor) will cause higher effective compression levels in the cylinders.
Basicly, too much compression or too much heat kills motors. And many factors go into both, including valve overlap and oil viscosity.
YBLEGAL.NET ProfileProjectsParts For SaleSteel Braided Brake Lines • Front Camber Kit (Price Drop) • Manual Brake Pedal
Old 08-22-2008, 11:07 AM   #4
Eh?
I'm going to search for that Static vs. Effective now, there's so much to figure out lol
indeed, done.
Old 08-22-2008, 11:27 AM   #5
YBLEGAL's Avatar
myspace
<the truth>
Very nice explination! Sets straight a lot of what I've learned so far too. Lots of info organized in such little space!
Old 08-22-2008, 11:33 AM   #6
Eh?
I second that.. +rep
indeed, done.
Old 08-22-2008, 11:50 AM   #7
YBLEGAL's Avatar
myspace
It wont let me rep you blanco, sorry. I have to spread it around more I guess.. but theoretical +1!
Old 08-22-2008, 02:26 PM   #8
is lol'ing @ you
newb's Avatar
Ride:  '98 Z28
Rep Power: 88 newb has a reputation beyond repute
newb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond repute
Send a message via AIM to newb myspace
Damn, I cant rep you either Blanco. +1 more theoretical rep.
Locate approximately as shown
"I'm a bad man." -Cassius Clay
Originally Posted by Battle Pope View Post
this thread makes me facepalm.
newb is offline   Reply With Quote
Old 08-16-2009, 09:57 PM   #9
Greenhorn
Rep Power: 0 sunfowerggs is on a distinguished road
Many thanks to ur post. I love it.
demande simulation pret personnel en ligne - Pret personnel en ligne et de comparer les meilleurs taux afin de... La demande de prêt personnelen lignedemande simulation pret personnel en ligne
sunfowerggs is offline   Reply With Quote
Old 08-17-2009, 02:40 AM   #10
is lol'ing @ you
newb's Avatar
Ride:  '98 Z28
Many thanks to your worthless bump of a year old thread.
Old 08-18-2009, 06:18 AM   #11
Ride:  Honda civic VTi EG6
Rep Power: 0 johnvtec is infamous around these parts
yeah your right because if your running high comp then your restriciting the amount of air the forced induction can allowe because it will create to much pressure on the engine but if you run lower comp then you can increase the amounts of boost pressure thats what makes big power.
johnvtec is offline   Reply With Quote
Old 09-10-2009, 06:47 PM   #12
Christmas Car
Ride:  93 4dr D15B, Greddy Short Ram, 4-2-1 Header, 2.5" Exhaust.
Rep Power: 8 RoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura about
^ we have another winner!!!
Ding ding ding!!!
RoughKnight is offline   Reply With Quote
Old 10-08-2009, 10:25 AM   #13
Rep Power: 14 78civic will become famous soon enough
But what engine type are you planning on 'building'? Honda?
Some engines don't like to be boosted, and some even have a hard time running High compression normally aspirated.
Whereas you can boost the heck out of others (just as long as you have it tuned to it's optimum) or run very high n/a and not many at all problems arise.
There are tons of articles on the web that you could be reading for years. Endynes' site had some good info, and reading/seeing what 'they do' when they build a motor really makes you think at a greater level.
Thinking on these things will bring you down to a more economical environment of a build.
Read of motors that are in the HP rang you might want to be and see what was done to their motors. pic a build and try to replicate within your budget. You may even try to get in touch with that builder to pick his/her brain. (watch out for the B/S too. in other words: read read read) Unless they 'race' they may talk your arm and leg off.
E
"If you can read, thank a teacher"
"If you can read it in English, thank a VET"
78civic is offline   Reply With Quote
Old 10-08-2009, 10:47 AM   #14
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
this thread is over a year old, but since the OP is still active on this forum im gonna leave this unlocked. Don't post to this unless the OP is willing to keep this topic going.
Anime Informant
reikoshea is offline   Reply With Quote
Old 10-08-2009, 04:02 PM   #15
Sorry, That would be nice if at a certain date the title would change color..
E
Is this b20 the high compression one? .:i.lIKE:.:eK9:.:lOTs:. HYBRID -> EG-EK / DC 2 10-22-2006 06:39 PM
Do I have too high compression #s?? 94CivicSlow Engine Building 4 07-27-2005 06:29 AM
High compression B17 SpoonTuNed Engine Building 1 05-27-2005 12:41 AM
High compression SLEEVES Elo'rin Engine Building 15 05-13-2004 12:29 AM
High Compression Pistons (for C5) ek9r Engine Building 8 09-19-2003 05:59 PM
