| | LinkBack | Thread Tools |
| | #1 |
| Super Moderator Join Date: Sep 2002 Location: New Albany, OH
iTrader: 0 / 0% Ride: 01 is300, 05 s2000, 03 rx300
Rep Power: 58 | if i raised my compression.. how should i compensate when adjusting my FPR. the car was running rich as hell, and i was planning on dropping the fuel pressure, but i'm thinking again since i raised the compression. do i need more/less fuel when having a higher compression? |
| | #2 |
| WRX Sellout Join Date: Sep 2002 Location: The left lane Age: 32
iTrader: 0 / 0% Ride: 2002 WRB Impreza WRX
Rep Power: 100 | If you're talking about higher compression, everything else aside, you shouldn't need any more or less fuel. Higher octane, of course. Think about it...you're compressing the same amount of "stuff" more, then igniting it....it's going to give you more of a bang. Shouldn't require any more or less fuel. |
| | #4 |
| Senior Member | it depends on how rich your car was running previously. its so hard to speculate, given the fact that i've never seen a dyno with your air/fuel ratio prior to the change in compression. |
| | #5 |
| Senior Member | and play around with it a little. try leaning it out in the lower rpm's...and or giving the car fuel to see how it reacts...as i know i can feel a difference with a drop in as little as 5hp over a given range. |
| compression, octane, and boost | rjbaker | Engine Building | 6 | 01-24-2004 03:03 PM |
| Static vs. Effective Compression | pissedoffsol | Turbo Information | 0 | 01-12-2004 12:43 AM |
| How to Compute the Compression Ratio of a motor | pissedoffsol | General Tech Articles | 0 | 01-12-2004 12:41 AM |
| higher compression | jordan | General Tech and Maintenance | 3 | 08-19-2003 10:34 PM |
| Benefit of using Higher Octane? | pissedoffsol | General Tech Articles | 0 | 09-28-2002 12:37 PM |
